Question about Fuji FinePix S2 Pro Digital Camera
Error I jusht bought a FujiFilm FinePix S2 Pro and it has been working great. But I just recently put it on my tripod and turned on the auto-timer and i clicked the shutter and waited for the picture to be taken. When I went back over, the info screen on the top read "Err" and the picture was not recorded and now that happens everytime I try to take a picture and so.. I can't take pictures with that camera anymore. Any suggestions?
    Sergeant:
  • 255 Answers
Agreed... Before anybody talks you into having a heartattack I would first check the following: Batteries, Lens settings (Aperture) and last but not least... The manual. Descriptions for all S2 error messages are in back.
Posted on Sep 12, 2005
    Sergeant:
  • 255 Answers
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
SOURCE:
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro won't turn on
I had a very similar problem a couple of years ago. Found intermittent power from AA source when battery tray was moved slightly while shooting. I ordered a new AA battery tray from Fuji ($50 I think), problem solved, no trouble since. The tray must hold the batteries tightly against the contacts inside the camera. Camera had only shot about 5000 frames when the problem arose. Hope this helps.
May 01, 2009 | Fuji FinePix S2 Pro Digital Camera
Fuji finepix s2 pro
the lithium batteries power the flash and some of the metering. But if they drop below a certain power, the camera dies. The F33 error is probably the accidental movement of the aperture ring on the lense. If you get the error, check the aperture ring is set.
Aug 11, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Fuji S2 pro, LCD screen flashes up write error.
It could be a faulty memory card. Or maybe dirty contacts on the card itself. Try swapping cards with a friend or your local camera shop and see if it works then. Maked sure the card is correctly inserted too. If the card formatted in the camera it should be OK. If it was corrupt it would show up during format. I hope you didn't buy the card off Ebay through an Asian or Chinese dealer. They are conning people with half a gbyte card marked as one gbyte. Some of them are reworked so they show the full Gbyte but when you go to format them they crash when you try to use them. Anyway it should be under warranty so ask for an exchange or even a different brand. BMW
May 31, 2006 | Fuji FinePix S2 Pro Digital Camera
Dark Images
Recently this happened to me just as I was walking in a church to shoot a wedding (major bummer). I had to rush and get my film backup for this. Anyway, this problem has ocurred with several examples of the S2 pro including mine, one other than mine that I know personally. The problem is the sensor. I quickly shipped to Fuji and they fixed the problem. I just got my camera back and so far it is working fine. Time will tell. I had to pay for the shipping only and turnaround was quick (1 week). By the way the camera was already out of warranty, but they gave a 3 month warranty after the repair.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
399 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
