Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Black cartridge problem
When I print a window pops up to show the average ink left in the cartridges. While this indicator is showing me that the Black (right) cartridge is almost full, on the LCD screen it show (remove and check cartridge on right) this is the second time in a row.
  • jemjam33 Sep 06, 2008
    ive had my photosmart for about 6 months and decided to use it yesterday, ive installed it, but everytime i try and use it says on the screen remove and check cartridge on right, ive tryed this a fuw times and cant seem to get it to work,please can you help me with tis problem thank you.
  • 234 Answers
Try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
If it still does the same then the printer is not detecting the ink catridge, the printer might have to be replaced.
Good Luck
Posted on Sep 01, 2008
I also have had this before with the <a rel='nofollow' href="http://www.hp-300.com">HP 300</a>. Power off the printer, remove the cartridge and put it back after 5 minutes may help.
Yours,
Steven
  • Steven65 Sep 01, 2008
    Sorry, this is the right link: HP 300.
I have a photosmart C4700 and it won't print in black How can I tell if it's out of ink?
Follow these steps to check the ink levels: >Click Start . >Click Printers and Faxes . >Right-click the icon for your printer , and then click Printing Preferences . >Click the Features tab. >Click the Printer Services button. The Toolbox window opens. >Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
NOTE:Depending on the printer, the estimated ink level indicators can vary in appearance.
>If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
Aug 13, 2011 | HP Office Equipment & Supplies
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
Have more questions? Please feel free to ask.
Hope this has helped.
Luck!
Mike
May 12, 2008 | Office Equipment & Supplies
Overiding Empty Cartridge error for Dell A10 962
Red flashing light on '8BK' small black cartridge on left hand side.
If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
Dec 13, 2007 | Office Equipment & Supplies
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not print black, but will not let me replace black cartridge
The Epson FAQ lists several techniques for resolving this problem. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview There is also an animation on how to replace the ink cartridges. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
Oct 14, 2006 | Epson Stylus 880 InkJet Color Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
1,618 people viewed this question
Seeker5211
Seeker5211
