Light since we say that whenever a body transmits light it is due to emission of electrons in higher excitation state then also we cannot see human body illuminating as it also contain electrons?
    Brigadier General:
  • 5,158 Answers
Actually if you live in new jersey you would probably glow in the dark
Posted on Sep 02, 2008
My 2001 dodge intrepid failed emissions says due o excessive of readiness monitors 'Not Ready'
you must not clear codes or unhook battery after doing what they call a drive cycle which resets monitors to a ready state. http://www.lhforums.net/forums/showthread.php?2755-OBD-II-and-your-Next-State-Inspection
press helpful button
Dec 18, 2015 | 2001 Dodge Intrepid
My TV brightness is very low? It's a telefunken.
Maybe your light blub inside TV is dimmed down due to long time usage. This can be replaced. Also check light settings in the option menu.
Apr 06, 2015 | Televison & Video
Are they recalling turkeys
Hi
Yes turkeys can get bird flu, and in exceptional circumstances this can be transmitted to humans.
BUT I suggest you go here as the current reported recall is a hoax:
turkey recall 2014 Google Search
Cheers
Nov 24, 2014 | Facebook Computers & Internet
WHAT IS ICP
An integrated circuit piezoelectric sensor or ICP sensor is a device used to measure dynamic pressure, force, strain, or acceleration. It contains a sensing element made of a piezoelectric material, which converts mechanical strain into an electrical signal, and anelectronic circuit to amplify this signal and transmit it to an external device.
ICP is an abbreviation of "integrated circuit piezoelectric", and is a registered trademark (no. 1,603,466 in the USA) of PCB Group, Inc., parent company of PCB Piezotronics.[1] There is a similar non-proprietary standard called IEPE, which stands for "integrated electronics piezoelectric."[2]
In an ICP sensor, the built-in electronics convert the high-impedance charge signal that is generated by the piezoelectric sensing element into a usable low-impedance voltage signal that can be readily transmitted, over ordinary two-wire or coaxial cables, to any voltage readout or recording device. The low-impedance signal can be transmitted through long cables and used in dirty field or factory environments with little degradation. In addition to providing crucial impedance conversion, ICP sensor circuitry can also include other signal conditioning features, such as gain, filtering, and self-test features.
The electronics within ICP accelerometers require excitation power from a constant-current regulated, DC voltage source. This power source is sometimes built into vibration meters, FFT analyzers, and vibration data collectors. A separate signal conditioner is required when none is built into the readout. In addition to providing the required excitation, power supplies may also incorporate additional signal conditioning, such as gain, filtering, buffering, and overload indication
Aug 14, 2014 | Cars & Trucks
How to get optical to work
You hear about fiber optic cables whenever people talk about the telephone system, the cable TV system or the Internet. Fiber-optic lines are strands of optically pure glass as thin as a human hair that carry digital information over long distances. They are also used in medical imaging and mechanical engineering inspection.
In this article, we will show you how these tiny strands of glass transmit light and the fascinating way that these strands are made. Fiber Optic Patch Cables
May 01, 2014 | Hitachi 43UWX10B 43" Rear Projection...
My 05 300 chysler has had a new throttle body system put on and car still not fix.The lighting bolt still pops up an emission sign do also....HELP!!
whenever a throttle body is disconnected on a 300c it needs to be programmed with a star scan device; was that done? it will have bad idle or no idle if it was not programmed.
Feb 23, 2014 | 2005 Chrysler 300
Emissions Code
Error Code: P0441
Fault Location:
Evaporative Emission (EVAP) System - Incorrect Flow Detected
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
- Purge control VSV connector disconnected.
- Evaporative Emission (EVAP) Canister Purge Regulator Valve is faulty/jammed.
- Evaporative Emission (EVAP) Canister Purge Solenoid Valve faulty/jammed.
- Evaporative Emission (EVAP) Canister Sealing faulty.
- Pipes between Tank Breathing and Throttle Body leaky/blocked.
- Hose connection(s).
- Intake leak.
Solutions:
- Check Evaporative Emission (EVAP) Canister Purge Regulator Valve.
- Perform Output Test.
- Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve.
- Check Evaporative Emission (EVAP) Canister.
- Perform Basic Setting.
- Check Pipes between Tank Breathing and Throttle Body.
Jan 10, 2014 | Toyota Cars & Trucks
1999 SOLARA CHECK ENGINE LT
Don't use any higher octane fuel than what the manufacturer recommends, that will cause problems with cold starts and other poss issues due to the diff of the fuel burn rate. As far as the check engine light goes there are 100 different things that turn the light on, all are related to faults that have occurred in the electronic control of the engine, emission control system and in some cases the transmission, have the powertrain control module tested for trouble codes, whenever the light comes on one is stored.
Dec 14, 2008 | 1999 Toyota Camry Solara
2001 toyota corolla check engine light is on. Code reads P420 low threshold. Changed front and rear Oxygen sensors reset the light and drove the car 50 miles and the light came back on. the car will not...
Mass Air Flow sensor! Just remove your air filter cover. Go to Auto Zone and purchase some solvent. Spray past the air filter and it should correct the problem. If not, replace the Mass air-flow sensor. This is commonly mistaken for an oxygen sensor. Mine did this and I followed these steps and it fixed the light. BTW, the light stayed on for 5 years before I fixed it. Never hurt anything. It's normally something to do with emissions. Dummy lights. :)
Aug 06, 2008 | 2000 Toyota Corolla
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
