Doubling the pages when printing
My printer is HP color laserjet 2840.Then here is my problem with this printer, when ever i print any document it's double up the pages and stops after printing two or so copies then write a massage says unexpected number press enter to continue, Hei! its consuming too much time and also waisted the paper.I need the solution for this problem
  • William VITULLO May 11, 2010
    I don't understand too much you issue.
    But I think your printer has a problem with the paper tray, this is why it takes two pages instead of one.
    Scholar:
  • 62 Answers
This sounds like a paper feed problem. The problem is most likely with the friction pad, a small rubber or cork pad that makes direct contact with the feed rollers. I would also suggest replacing the feed tires. For most HP printers, this is a repair that can eaisily be done by the consumer. You might also try cleaning the friction pad with alcohol. Hope this helps,
C
Posted on Oct 07, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
HP color laserjet 2840 for Mac -- Pages print but are totally blank. Appreciate if you can advice A.S.A.P
  • The sealing tape might still be in the
    print cartridges.
Solution "Verify that the sealing tape has been
completely removed from the print
cartridges."
  • The document might contain blank
    pages.
Solution "Check the document that you are
printing to see if content appears on all
of the pages."
  • The device might be malfunctioning.
Solution "To check the device, print a
Configuration page."
Jul 06, 2011 | HP LaserJet 2840 Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
HP2840 color printer
I opened UDP port 9100 through my firewall and my documents now print.
Aug 22, 2008 | HP LaserJet 2840 Printer
53 people viewed this question
jasbo
jasbo
