Question about Toshiba DKT-2010 Corded Phone
Not to sure what the (PCOU2A)card does? - Toshiba DKT-2010 Corded Phone
  • 31 Answers
Pcou card is a trunck card for old toshiba phone system.
Posted on Oct 11, 2008
Why does phone display 'install SIM card'?
Just to be sure, remove the SIM card and reinsert it to be sure it is fully seated.
Dec 28, 2015 | Cell Phones
Sd card won't click down
There may be several reasons.
1. Is the SD card the right size? Check to confirm your card is the right size for the camera.
2. Make sure you face the card the right way. If you try inserting the wrong-way, it won't slide into its compartment.
3. Check to make sure that the sliding switch on the card is aligned to 'ON'
4. Make sure the card compartment is free from obstruction
When you try the 4 points above but cannot slide the SD card into the camera, let me know.
Sep 01, 2014 | Kodak Easyshare C183
Readon 6970 grapic card overheats
You should check to make sure the fan on the card is working properly. Make sure everything is plugged in correctly. If I am correct, that card requires two connections from the power supply. Also check the card and make sure it is free of dust and lint. You may also need to make sure you are getting good air flow in your case.
If everything is proper, you should see about replacing the card via return or replacement through the manufacturer or retailer.
Sep 26, 2011 | Computers & Internet
My card is not detected
Remove the card do a reboot and try again if you get nothing Navigate to the Device Manager and check to see if there is a problem with your card reader. If there is try to resolve the problem then you should be good to go.
NOTE: ALWAYS be sure to SAFELY REMOVE any and ALL Removable Hardware.
Jun 12, 2011 | SanDisk 2GB microSD Memory Card
Sound error
Check the computer is not in a muted state,
Make sure the headphones and speakers are in the correct sound port.
Make sure you have selected the sound card to use.
Make sure the driver is installed for the sound card.
You can check the if the sound card driver is installed by going to device manger and checking if the sound card is listed under the sound,video and game controls.
If the sound card is listed and there is a symbol like an ! mark then it may not be installed right.
If you cant find the sound card in device manager then the computer is not recognizing the card, so make sure it is in the right PCI slot etc..
May 07, 2011 | Office Equipment & Supplies
Pictures will not load to memory card
first of all make sure you have choose the memory card as your default option to save pictures. if you are sure about this, secondly make sure your memory card is working. the golden boxes ( metal plates) in memory card should not be covered with dirt so make sure you erase the gold plate with a eraser(rubber) and make sure it is gold in colour and re insert it into your camera . else try with a different memory card
Aug 31, 2010 | Nikon COOLPIX P80 Digital Camera
Memory card is not being read
Here are two suggestions:
1) Make sure the card is properly formatted. If you are sure the card is blank, you can use the Format utility in the Set-up menu to format the card.
2) Make sure the card is not write-protected. If looking at the card with the gold contacts facing you and up, there may be a little tab that can be slid to protect the card. From this angle, you can protect the SD card by sliding the tab down (away from the gold contacts) or unprotect the card by sliding the tab up. Sometimes the tab can get bumped part way between the two positions.
May 19, 2010 | Pentax *ist DL Digital Camera
Memory card when i turn the camera on it take
Check to make sure you...
1) have the card seated properly in the camera.
2) make sure the card your using in the camera is not full.
3) make sure if it's an SD card that it's not physically locked.
Rob
Mar 09, 2009 | Casio Exilim EX-S500 Digital Camera
Do you know
Wow, an oldie but a goodie. A DK-424 with 10 button sets....doesn't quite seem right, but the card is a 4-port trunk card (C.O.) without Auto Busy Redial.
Your base cabinet 424 can expand to 16 trunks and 32 phones in that cabinet.
Carl
Sep 01, 2008 | Toshiba DKT-2010 Corded Phone
I cannot copy my saved data to my SD card
make sure the lock on your card is up (unlocked position)
make sure you have a lock on your card! (the lock is opposite the cutaway corner)
make sure the contacts are clean
make sure you do not use a "SD HC" card most systems cannot use these cards.
Jul 08, 2008 | Video Game Consoles & Games
Toshiba DKT-2010 Corded Phone Logo
27 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
