My System: WinXP Home&Pro Edition with USB IrDA and Jornada 520. I had no problem at all until i started downloading some piece of software from the net. Suddenly my jornada stopped communicating with WinXP (sync error) but works fine as a guest. So, i made a full backup throught the guest and then hard reset. After that i made a typical restore for my valuable data and the problem was still there! So, i did another hard reset and i made a partnership (without trying to restore). I synchronized the data fine (!), but i lost the whole settings.... Where is the problem? The software i tried to launch was: 1) greek support trial from penreader.com 2) flash player for pocket 2002 without a chance 3) money 2001,2002,2003 support without a chance to make it work 4) the ruler utility 5) the tuner utility from penreader.com that's it any ideas?
SOURCE: USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
SOURCE: Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
SOURCE: Jornada 720 software
hi there
please let me know that what kind of program you are looing for?
SOURCE: i have a hp jornada 520 but have lost the serial
The HP Jornada 520 Series Pocket PC has been discontinued, and some of the accessories may be difficult to locate. They may be available in one of the following ways:
The Part No. for your Serial Cable = F1819A
Hp Internal Crew No. for your Cable = F1798-80014
Regards,Waqar.
