Question about Navman F20 GPS Receiver
Navman F10.........Just Out Of Warrantity
When Unit is turned on A message in red appears- unable to locate internal memory, contact tech.
  • tipton29 Sep 01, 2008
    red message comes on.unable to detect internal memory,
    it was working fine this morning ,noe this
    Genius:
  • 1,239 Answers
Hi sir,,
may be memory card correpted..
Posted on Sep 01, 2008
I reset my F series,now it tells me
unfortunately, per C-Net's review page at "http://www.cnet.com.au/navman-f20-339272352.htm#comments" there may not be any software available as that these units are now "obsolete". but there does not seem to be any "free" software at all.
hold it! just found the software page from the company at "http://www.navmansupport.com.au/All%20Navman%20FAQs/Software/F%20Series.htm" for this unit. could not find a "direct" link to the download, but you may have better luck.
it would seem that there are drivers in windows for this ( according to what I saw on the site)
on some further searching, it seems that there is a sd card in the side that may be loose, check that out, too!
Mar 02, 2012 | Navman F20 GPS Receiver
F20 GPS
Remove memory and put it back, if it still does not work memory is probably faulty.
May 24, 2008 | Navman F20 GPS Receiver
Navman f20 wont turn on says F20 ERROR UNABLE TO DETECT INTERNAL MEMORY
Not much to do here I'm afraid. a repair is needed. If your device is not under warranty anymore, you can get in touch with Navman / Mio, they have a trade in offer towards a new Mio device
Feb 22, 2011 | Navman F20 GPS Receiver
Reset navman F10 sat nav
Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
Sep 23, 2008 | GPS
Software Problem with Navman S70 3D
you have to contact Navman from thier website and then return it to them and they will repair it for you
Stu
Sep 21, 2008 | GPS
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Jul 14, 2008 | Navman F20 GPS Receiver
Unable to register newly acquired GPS Navman S80 on your address at www.navman.com.au/register
Also unable to regster my s90i which is giving me wrong directions. Wirimu
Apr 11, 2008 | GPS
Navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
Jan 12, 2008 | Navman F20 GPS Receiver
NAVMAN F20 failure - unable to detect internal memory
I think that the micro SD card inside the GPS is not in the good position, it is necessary to remove the grey sticker on the rear of the GPS and open the hood to access the SD card and then you can plug it in good position.
DAMS
Dec 25, 2007 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
73 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
