Question about Metz 45 CL-1 Flash
Use in canob 450D
Can I use this flash with Canon 450D digital camera ?
Is this flash dedicated to canon 450D ?
    New Friend:
  • 30 Answers
No. You can only use the camera in manual mode, setting the shutter speed to, say, 1/125 sec and the aperture: according to the working aperture on the flash. The flash has to be in auto mode. The physical connection between the camera and flash can be either a standard PC cord, originally supplied with the flash plus a hotshoe-to-PC-female "cube", or an SCA305a cable plus an SCA301 standard foot. Of Metz 45 series only the 45CL4 Digital together with an SCA3102 M4 module is dedicated to the Canon EOS digital series.
Posted on Dec 08, 2008
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Jul 26, 2014 | Canon EOS 450D Digital Camera
Error code 001 with canon 450d
Seems a lot of people are having the same problem. Take the lens off the camera and clean the little gold contacts (metal squares) on both the lens and the body with isopropyl alcohol or pre-moistened len wipes.
Mar 21, 2013 | Canon EOS 450D Digital Camera
Which would you recomend i buy 450d or 40d
You can compare these two products from the web site below:
http://www.dpnotes.com/canon-40d-vs-canon-450d-digital-rebel-xsi/
good luck and do rate the solution if helps
Dec 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Oct 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Compatibility of cullman cx35 with canon 450D
It shouldn't hurt the 450D: you won't be able to use TTL mode.
Aug 21, 2009 | Cameras
How do I know if Vivitar 285 fryed my camera
camera sync terminal wont work with even canon recommended flash.This can be the way to test your camera got damage.
Apr 14, 2009 | Canon EOS 450D Digital Camera
Occasionally I get 'ERROR 5' appear on the display on my EOS 450D - it is suggested that the pop-up flash is being impeded, but I know that it isn't. What is happening?
This is a common canon mechanical error.
Most of there SLRS do this the release inside the pop up flash hangs either due to weak spring or release catch itself. If it hangs for even a split second you get error code.
Try This.
  1. Clean Flash Release & Apply wd-40 with a q-tip to moving parts. DO NOT SPRAY INTO CAMERA. Use oil lightly.
  2. Or Assist flash when it tries to p up by lifting on flash gently. Maybe one day canon will fix this problem.
PS this happens to even Brand new Canons.
Mar 08, 2009 | Canon EOS 450D Digital Camera with 18-55...
When fitting a Canon 430EX flash to 450D,,light emits but flash doesnt fire, no flash in any mode.
Your camera may have been set to not fire external flash. Go to your menu, 5th tab. Near the bottom, there's an option for Flash Control. Select that. It should now show "Enable" or "Disable". Enable it.
Also "External Flash func. Setting" gives you more options for your 430EX.
Jan 25, 2009 | Canon EOS 450D Digital Camera
Metz 45 CL-1 Flash Logo
257 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
