Fishi - usenet poster
Rank: Wiz
Rating: 79%, 224 votes
We had the same problem with a Fuji FinePix s3000 purchased almost three years ago. Its been a terrific camera and has worked perfectly until just last week when it came up with the "Zoom Error!" problem in the view finder. Since then we have not been able to take a single photo. We did not expose it to any extremes of heat or cold and we did not get it wet, so that would not explain the failure.
I very carefully took the camera apart with a jewler's screwdriver and found that it is quite complex inside. To get to the zoom mechanism you have to remove 3 layers of circuit boards. Upon inspecting the zoom mechanism and the minature gear box I could find nothing obviously wrong or broken. Incidentally, don't try what some people suggest for other Fuji cameras about manually pulling the zoom out because you'll probably just strip the gear box. The mechanism is driven by a small motor about the size of a thumb-nail. I guess its possible that this had failed, but since I was not sure of the voltage and I didn't want to disconnect it, I didn't test it to see if it worked.
I checked to see if there was any sand or grit in the mechanism but it all looked clean. When I put it back together the zoom mechanism extended and stayed there. The screen still showed "Zoom error".
The only solution I can see is to buy a new camera of some sort. It seems that many of the Fuji cameras suffer from this zoom error problem so maybe a change of brand is in order. I think Fuji need to redesign their zoom mechanism.
