Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Volume cannot be operated by remote anymore how can i fix this problem
  • mattsalah Sep 01, 2008
    Thank you I will clean with aceton and see what happens
    All functions of the remote works except the volume
  • 927 Answers
Good Day, mattsalah;
You have two options:
1). Buy new remote part # 290P116010, $ 70.05, in stock
2). Repair remote by taking it apart and cleaning the contact with pencil eraser/acetone (finger nail remover).
Is the TV's remote not working or the "BOX" remote?
Good Luck, big IRISH.
Posted on Sep 01, 2008
  • MICHAEL MULLINS Sep 01, 2008
    Cleaning is better than buying. Be careful and good luck, big IRISH.
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Changed batterys late now cant seem to operate the sky remote to switch television on or off and also cant get the volume button to work anymore either. our television make is sharp
try to open your remote control remove the rubber key pad you will see their a round copper printed in the pcb clean it using an eraser.
Oct 18, 2010 | Televison & Video
Volume controls on the unit and the remote don't work ... the batteries on the remote are new ... the remote will turn the system on and off but will not operate the volume controls
Hello
Ok, sometimes some of the circuits on the circuit board of the remote itself malfunctions, thus some of the buttons will not work anymore.
I will suggest that you buy yourself a universal remote, it will be much cheaper than buying the origional remote that came with the unit directly from the manufacturer.
Just click on the link below and you will be directed to site where you can read some reviews and check out the prices on the corrosponding remotes.
http://www.remotecentral.com/
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 21, 2009 | Audio Players & Recorders
My KDS-R60XBR1 turn up volume to maximum loud and stays loud
Question:
Take the batteries out of both the remotes and then try to turn the TV on with it's On/off switch built into the TV.
If it turns on and the volume stays the same, then it must be an issue with one of the remotes.
If the tv turns on and the volume ramps up to max. Please check if volume knobs/buttons on the tv itself to see if they are sticking.
If they aren't, there is something wrong with one of the boards in the tv of course. This sure should be something a Sony Service Shop can fix. I don't think it will be expensive. Maybe a $100 to $200 repair if they do the work.
Blessings,
A/V Media Guy
Nov 20, 2009 | Cameras
Need a remote code for the Olevia TV for the Comcast remote
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Jul 09, 2009 | GE JASRM24912 Remote Control
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Rca rtd215 home theater system
some of them do this to save the speakers but try unplugging it over night and see if that reset it hop this inform you more.
P.S. I own two of them..
Mar 09, 2008 | Audio Players & Recorders
The volume control wont work anymore, is there a code to fix this
Your question isn't complete, but I am assuming your problem is that the remote contol volume doesn't work anymore. If this is correct, I assume that the remote pad board in the remote contol is worn or bad. Unfortunatly, there is not a good fix to repair the remote rubber pad. It may be time to invest in a new remote. I hope this helps. Have a great evening
Ed
NC Electronic
Mills, Wyoming
Jan 08, 2008 | RCA Universal Remote Control
Need manual control board (power,volume, channel and menu push buttons)
Manual push buttons part number should be CM35776-B01-SA.
Give me a few hours--I'll get the remote part number....T
Oct 30, 2007 | JVC AV-32950 TV
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
