Question about Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset
Headset problem I can turn on my bluetooht headset, but the light flashes slowly not allowing me to talk. It use to flah quickly and my voice would go through but now I cant get ti to flash fast. Please help me
  • 4,889 Answers
Did you check the headset'sbattery. May be its drained and needs to be replaced.
Posted on Sep 02, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
key (for about 5 seconds) until the
green indicator light starts to flash
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
phone. In some phones, you may
need to make the connection
separately after pairing.
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
When the headset is connected to
your phone and is ready for use, the
green indicator light flashes slowly
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to pair up nokia bluetooth headset BH-213 with blackberry curve 8520 ?
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Aug 31, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Call just drops. I can hear but person I am talking to can not.
While talking, turn up your volume on the headset. If this does not help return your bluetooth for defective voice pickup censer.
Nov 29, 2007 | Motorola Mobility H350 Wireless Headset
HELP
You can't program numbers vocally to you headset, you can only program vocally to your phone only if your phone has the voice dialing option. I have a H500 and can inform you of what I know. To turn on, hold button until blue light flashes once or twice, to turn off is the same thing. To pair your headset with your phone you have to hold down the call button until the light stays on then you use your phone to pair. After pairing the headset will flash quickly then discontinue. If you are using your headset and receive another call, you press the call button on the phone to answer the other line and to also release the call. The volume up and down buttons are found on the top and bottom of the headset, up and down is dependant on which ear you wear your headset. To mute, hold both the volume up and down buttons at the same time, this also unmutes the call. Hope this helps!
Sep 08, 2007 | Motorola Mobility H500 Wireless Headset
Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset Logo
67 people viewed this question
Top Sony Ericsson Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
sandrasteven
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
