Component flash9d.ocx or one of its dependencies is not correctly registered: a file is missing or invalid
  • Anonymous Apr 11, 2009
    component flash9d.ocx or one of its dependency's is not correctly registered a file is missing or invalid
  • 3 Answers
Erm hiya The Same Things Happinin With Me Plz Help Me and This Person i cant come back on this website so if you have an answer plz email me on becca099@hotmail.co.uk
Posted on Sep 16, 2008
    Genius:
  • 2,785 Answers
Plz reinstall the software
Posted on Sep 01, 2008
Can't access all games
UPDATE THE DIRECT X.MAYBE A BETTER VIDEOCARD
Jul 02, 2013 | Encore 500,000 Games [pc Game]
Even though it says i have installed the moultrie plot stalker software, i am gettting this error message when i click to open - component comdlg32.ocx or one of itsb dependencies is not correctly...
Had the same problem. Right click the icon for plot stalker. Click on properties, which is at the bottom of the list that pops up. A window will then pop up with six tabs at the top. Click on compatibility. Down towards the bottom of the window click on the checkbox that says " Run this Program as an Administrator." Problem Solved!
Sep 20, 2011 | Moultrie Cameras
HAVE A CD WINDOWS 95, 98, 2000, NT 32bit application trying to install but I get a error message - component CSTEXT32.OCX or one of it's dependencies not correctly registered - a file is missing or invalid
The only time I usually see this is on copied CD's. Windows sets those in a special place that most copy software doesn't look as a protection against piracy. I am not saying you have bootleg disk but that is the only time I have seen that. If those are original CD/DVD's and you don't need the information on the HD saved, Try partitioning and them formatting the HD again then try an install. For Win 95 and 98 format to Dos, for 2000 and NT you can format to the more efficient and better NTSF format.
Oct 29, 2010 | Computers & Internet
I get an error message that says Component 'MSCOMCTL.OCX' or one of it's dependencies not correctly registered: a file is missing or invalid.
Hi
first make sure you have the file MSCOMCTL.OCX in your system
if not you can search and download the file copy to system32
then run this command -- regsvr32 mscomctl.ocx
it should solve this problem
Sep 18, 2010 | Coby CX-R190 Digital Voice Recorder
I was trying to install a program for my college
Your program did not install properly. Based on the error message "Resize32.ocx" or something it needs to run did not install properly. Uninstall through control panel-add/remove programs and reinstall.
Jan 14, 2010 | Sony VAIO PCG-K33 Notebook
There was a runtime error 339 on my pc. component 'MBPrgBar.ocx' or one of its dependencies not correctlt registered: a file is missing or invalid
1->download the file . google it.
2-> copy this file to system directory then type the following in run command
3->regsvr32.exe MBPrgBar.ocx
Jan 12, 2010 | Audio Players & Recorders
Software not instaling correctly
I am having the same problem I've look everywhere can't find anything.
please if you found the solution let us know.
thanks
Apr 10, 2009 | Coby CX-R190 Digital Voice Recorder
Laptop wont turn on properly
A vital component that windows requires to run is corrupted. To fix it, you need the OS disc
In Windows Vista, there is usually a second partion on the harddrive that you can load by pressing F8 (or F10 depending on your system) and selecting the repair your computer option (depending on your manufacturer, you might need to input a password, after that choose the repair your computer option or solve startup problems
In Windows XP load the disc and open the recovery manager.
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
602 people viewed this question
David Payne
David Payne
