Question about Epson Stylus C86 InkJet Printer
Epson ICC profiles
My printed colors don't match the monitor colors. Where can I download Icc profiles for a Epson c86 ink jet printer?
  • workrabbit Sep 01, 2008
    Please can you tell me how to download ICC color profiles for an Epson C86 InkJet printer (ie paper types). I am having problems with my printed colors not matching the workspace (monitor) colors.
  • 353 Answers
Since there has been no interaction for a lot of months, I think we can call this one "Poster Solution"
Posted on Mar 28, 2009
My color photos print darker then they appear on my monitor. I use Huey pro to callibrate, I use photoshop and print to an Epson 3880, using the Epson supplied profiles. I turn off printer management and...
You need to select the correct Printer Profile for the type of paper you are using. If you are using non-Epson paper, you need to download the ICC Profile from the paper mfg. website.
You also need to check if the paper is comparable to an Epson paper that the printer supports. If the paper your using is not comparable to any Epson paper the printer supports then you might want to try using another kind of paper. Epson prefers Epson Paper. You can also try any non-Epson paper as long as it is comparable to any Epson paper the printer supports. Try to go to their website and look at the printer's specifications. It lists all type of paper the printer supports.
Jan 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
I am the Graphic Artist and Printer for a public library. We have a logo that has the Pantone color PMS 375 green in it. I mix my own inks and have no problem reproducing the color properly on a printing...
Laser printers, although they have a larger color gamut than a CMYK offset press, still will not be able to reproduce a majority of Pantone special colors.
Professional inkjet printers, especially those using more than 4 inks, are far better at this - the ink pigments are more color-pure and concentrated than those in laser toners.
Remember, that Windows print drivers work in RGB, and use ICC profiles to convert color data to CMYK components for printer. If you have a CMYK file, and look at it on your monitor, it's converted (using monitor ICC profile) to monitor's RGB colorspace, and then back to CMYK with the printer ICC profile when printed. Converted twice with ICC, which always introduces distortions...
If you have a properly calibrated monitor, and a good printer profile installed, you have better chances of reproducing screen colors on the printer, especially if you work in RGB.
As a simple, but laborious solution, I would suggest preparing "swatch sheets" yourself using some graphics software. Preferrably in RGB, not CMYK. A series of gradients with the green component going from, say, half way to maximum, and other components in various combinations, like R0 B0, R10 B0, R20 B0,... then R0 B10, R10 B10, R20 B10... and so on. Print those, and try to find a spot in the gradients that is the closest to your color sample, and then make swatches with smaller increments around that color to find the best RGB combination.
Good luck :)
Nov 13, 2009 | HP Color LaserJet 5550hdn Printer
Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
Mar 24, 2009 | Epson RX595 Photo All-In-One Printer
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Colors off. saturation incorrect.
I've had similar color management problems.  I've lacked consistent color management from day one with this printer.  I use standard Epson ICC profiles for paper /printer combinations.  In setup I select the specific paper type (mostly Epson Premium Luster paper.  SP4800 PLPP PK 288.icc profile. I use Print with Preview, Color Handling "No Color Management".  Under Print Setup I select Premium LusterPhoto Paper. Under Printer Color Management I select Off (No color management).
Prints with these settings are so far off from the colors in the preview image the only thing they are good for is the shredder.  In addition, I can use the same profile and printer settins and prints are different from one print to the next without changing any settings. Very frustrating.
I've gone through several hundred dollars trying to get consistent color management.  I also use an Eye One Greytag Mcbeth color management tool for both monitor, and for some papers, custom profiling.  Nothing seems to improve.
I did talk with a consultant and was advised to do a good head cleaning (which was done) and also use Disk Utility to repair permissions (also done) but still no improvement. My consultant from a reputable Pro Photo source advised me that I was not alone and that he ad numerous users who were experiencing similar color management problems.  This vendor no longer carries Epson because of  these continuing problems. Try the head cleaning and repairing permissions.  As for me, I've been struggling twith these problems for over a year.  I'm looing at trading in my Epson 4800 for an HPZ3100. This is probably overkill for my needs as it is 24 inch capacity but i like that it has an Euye One photo sensitometer built into the print heads.  I'll be going to the vendor and testing this unit later this week.
Aug 13, 2008 | Epson Stylus Pro 4800 InkJet Printer
Error message
The ICC profiles on your printer are corrupted.. Click here to download new profiles.
Apr 16, 2008 | Epson RX595 Photo All-In-One Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Color problem in Epson Stylus Pro 4800
You can have problem whit the black ink. Try to print black text. And see it its real black a a green one.
If the text, print in black green it you have problem whit the black cartridge. If so change the cartridge.
Nov 15, 2007 | Epson Stylus Pro 4800 InkJet Printer
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Epson Stylus C86 InkJet Printer Logo
572 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
