Question about Palm Tungsten E2 Handheld
Fatal error message
How do I deal with a Emul68KMain.c,Line:403.illegalinstructionCA7Dataddress00786DA4 fatal error. I have reset, hard reset, but still have problem.
    Master:
  • 473 Answers
This error can only happen when you previously have another HH hotsynced to the same username you are using right now. troubleshoot by: Do a hotsync. Hard reset e2 hotsync to a new username export-import data if you are using PDS for your PIM reinstall all 3rd party software.
Posted on Sep 12, 2005
SOURCE:
On documents to go when I click on a document I get the following error: Emul68KMain.c,Line:403,illegal instruction 8888 at address 009524DC. What is this and how do I fix it?
You can probably fix that by deleting then reinstalling the program. This is a program error not a hardware thing. You may have to update the program to get rif of it. One some palms you had to run a palm patch to update the operating system to get rid of these type of things.
Mar 09, 2010 | Palm Tungsten E Handheld
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Documents to Go: Fatal Alert
It could just be that document, but I suspect if you've followed typical trouble-shooting steps you wouldn't be posting unless you already tried other documents. If that is the case, I would recommend you uninstall and reinstall documents to go from your device.
Feb 13, 2009 | Palm Tungsten E Handheld
Spt 1800 hand held - fatal exception error message
It needs internal hardware repair. I have done thousands. Send your number, if you think you would like to have them repaired. Thanks
Dec 11, 2008 | Symbol SPT 1800 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device. The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Palm Tungsten E2 Handheld Logo
157 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
