Question about Porter Cable Porter-Cable 7311 Offset Laminate Trimmer Base
Will a Porter Cable 7312 offset base laminate trimmer also work on Model 7301 HD POWER UNIT
I have Porter Cable 7301 HD Power Unit . If I purchace a  7312 offset base laminate trimmer will it also adapt to the 7301 power unit  ?
Thank you ,
Glenn  ( Consolidated Builders )
Consolidatedbuilders @cox.net
    President:
  • 1,996 Answers
I think it's meant to fit the 7310 trimmer, as the series numbers are in sequence. But when I look at the parts list for the 7301 & 7310, they seem to have the same motor housing part number, which indicates they are more or less the same size, no?
Check at the following website, http://www.dewaltservicenet.com/SearchResults.aspx?q=laminate%20trimmer
They also provide the means to ask them a question, if you're not sure you want to risk returning an order, in which case you want to link:
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/ask.php?p_sid=tZeaxJtj&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNzM4LDE3MzgmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x
I hope this info allows you to sort it out.
Posted on Mar 26, 2009
I have a 7301 power unit, 7309 trimmer base, 7311 offset trimmer base and the 7318 tilt trimmer base. The problem I am experiencing is with the power unit. The shaft spins but once I use the lock pin it...
first things first, the lock pin has a spring that is supposed to push it away from the shaft after using, if it is not releasing there could be a burr on the shaft/pin or the spring might be missing. the electrical smell can be from the field or armature and the freezing up might be a bearing which can lead to that smell. I would suggest going to "dewaltservicenet.com" and you can download the owners manual/breakdown for this tool. I think that I saw list price around 63.00 for the trimmer so I would not put a lot of money in the repair. They are not that hard to take apart so let me know if you need more assistance and I will try and help
Apr 22, 2011 | Porter Cable Porter-Cable 7301 5.6 Amp...
Porter cable 7310 has broken spindle lock. THis is a brand new router and the spindle lock pin is broken and the motor will not spin. what is the best way to fix this
you would have to remove the bottom section of the motor housing. this would require removing the collet nut and the screws holding the housing in place. I would suggest going to "dewaltservicenet.com" and downloading a breakdown before attempting. It is not really that hard if you are mechanically inclined. The pin is more than likely jammed into the armature shaft that locks and that is why the motor won't turn. Let me know if you need more assistance.
Feb 20, 2011 | Porter Cable 7310 Laminate Trimmer
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
How to check if coil is ok for 7301 router? Do you check it like a fuse for cont?
Yes, but instead of virtually "0" ohm's, you should read some resistance. The resistance amount can be roughly calculated as the voltage of the device, divided by the amperage rating of the device.
If you don't read anything, then the thermal protector or fuse has failed open.
Dec 21, 2009 | Porter Cable Tools & Hardware - Others
Is there a .pdf manual available for the Porter Cable 7311 offset base?
yes go to Dewaltservicenet.com and type in your model number and it will direct you to a manual it is 25 pages long. If I have helped you would you please rate this response accordingly and thank you.
Sep 17, 2009 | Porter Cable Porter-Cable 7311 Offset...
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate Support
# Use a straight base. # Make sure the bit height is correct. To adjust the height, loosen the base and turn the wheel on the side of the tool. When you've got the right height, tighten down the base. # Rest the tool over the top of the work piece, then turn it on. # Push the tool forward to trim around the edge of the work.
Aug 27, 2008 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate Trimmer troubleshoot
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Aug 27, 2008 | Ridgid 120V 6.0Amp Laminate Trimmer
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Porter Cable Porter-Cable 7311 Offset Laminate Trimmer Base Logo
433 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
