Question about Mitsubishi WS-55809 55" Rear Projection Television
Red line swirly red line
    Genius:
  • 1,694 Answers
Replace Convergence IC's = STK392-570.......
Test................T.
Posted on Sep 01, 2008
I have an olympus sz 14 and have a swirly white lines when I try to take a photo
Please check the shooting mode.
Restore Default might help
Sep 08, 2014 | Olympus Cameras
Need instructions for DQ Blizzard Maker
1st add crushed ice and equal water outside the tin in the blizzard
2nd add 3/4 of salt to the the salt water
3rd put the cap on and in a separate cup mix ice cream mix and 3/4 of half and half and mix until completely dissolved
4th put the mix in the tin cup and add the cap
5th stir with flat spinner not the swirly one spin for 10 min when done push ice cream with swirly stirrer
Nov 01, 2013 | Spin Master 1001130 DQ BLIZZARD MAKER
Red tint,double pictured red, kinda swirly
Replace Both of your STK ICS they will have Part number on them example STK392-110 if 110s use 150s Call Mats 1-800-628-1118
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
SWirly lines but no menu
Hi, this sounds like a hard drive problem. Try taking your hard drive out and putting it in another PS3 to see if it does the same thing. If it does, then your hard drive is damaged and needs replaced.Your hard drive is located on the side of your PS3, pop the cover off and remove the retainer screw and slide it to the front of the PS3 (pull straight out on some models).
Aug 17, 2009 | Sony Playstation 3 (PS3) Console
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Green lines through out the screen
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
May 15, 2007 | Hitachi 52LDX99B 52" Rear Projection...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
