Question about Electrolux Washing Machines
Drain hose disconnected - Electrolux Washing Machines
  • 78 Answers
Ah that is a problem, re-connect it
Posted on Sep 01, 2008
  • Klutch Davis
    Klutch Davis Sep 01, 2008
    could you expand on the problem a bit?
Where are drains located on a 2003 chevrolet impala sunroof?
They go down inside front A pillar an inside rear D pillar . To get at them you need to take trim off an the headliner down .
Sunroof Housing Rear Drain Hose Replacement (Impala)
Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior Trim. Remove the rear quarter lower trim panel. Refer to Rear Quarter Lower Trim Panel Replacement in Interior Trim. Disconnect the rear sunroof drain hose from the sunroof module rear spigot. Remove the tape from the rear sunroof drain hose tube.
Disconnect the rear sunroof drain hose from the rear sunroof drain hose tube. Remove the rear sunroof drain hose tube from the upper retainer clip. Remove the rear sunroof drain hose from the rear pillar
The front is simalier .
Dec 22, 2015 | 2003 Chevrolet Impala
How do u replace the drain hose on the inside that is connected to the pump
most washer are set up pretty much the same ill do this by number so you can follow
1 make sure you empty washing machine either by spin cycle or manual drain through kick flap at front make sure you have rags towels bowl 2 unplug the plug from electrics 3 turn water supply off at wall disconnect water inlet pipe 4 now all electrics and water are disconnected you need to disconnect the drain hose usually attach to drain pipe behind wash be careful these are usually full so drain off 5 if you can manage yourself carefully put washing machine on its side put some towels down to protect 6 underneath usually to the front right bottom is the sump pump with the sump hose black and the drain hose grey and the manual drain hose now either by clip or screw loosen the drain hose it is usually attached up the sides by clips they can just be pulled off one free from the sump motor just pull it through if refitting remember its just all reversed what you have done good luck
Mar 10, 2013 | Siemens WFXD5200UC Front Load Washer
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Jan 03, 2013 | LG LDF6810ST Stainless Steel Built-in...
Water sprays out and runs on floor during final spin cycle.
Sounds like a clog, either the drain tube, drain hose, or drain pump/diverter valve.
  1. If your drain hose is connected to a drain tube/pipe, it's possible there's a clog in the plumbing somewhere. Running a snake through the drain tube should fix this
  2. Disconnect the drain hose and look for a blockage. Sometimes lint, or paper will become lodged inside the hose and water will back up
  3. The drain pump/diverter valve is a common place for a backup to occur. To inspect the drain pump, unplug the machine and disconnect the drain hose from the drain tube. Put down a blanket or towel and tilt the machine forward. At the bottom of the machine you will see the drain pump with a hose connected by a clamp. Using pliers, disconnect the clamp. There may also be a mounting screw holding the drain pump in place. Unscrew the mounting screw. Now the pump should pull away freely. Using a small flathead screwdriver or tweezers or even needlenose pliers, you should be able to dig out any obstruction. Typically paper that has fallen out of pockets will get stuck in the drain pump forcing water in the other direction, causing it to spill out onto the floor.
Below is a helpful video to both check and remove a drain pump / diverter valve.
Sep 09, 2011 | Fisher Paykel EcoSmart GWL15
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
Drain problem
The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
If checking for leaks, feel the hoses where they connect to the pump, for wetness and check the ground right under the connections. If they are wet, it may be a loose or improperly mounted clamp, a damaged pump housing or a leak in the hose itself.
If checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
Reconnect the hoses and replace the clamps. Replace the lower panel and restore electricity to the dishwasher.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
Drain washer pump for winter
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Nov 11, 2009 | Office Equipment & Supplies
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Excess water left in the dishwasher, water not draining. I have checked all pipes and checked all filters which appear ok
  • Check sink drain and drain hose for restrictions . The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Aug 20, 2009 | Fisher and Paykel DS605I Built-in...
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
