Question about Sony Cyber-Shot DSC-H1 Digital Camera
Purple Fringing with H1
Took some photos this weekend at my sons soccer game and boy was I disappointed in the amount of purple fringing from my H1. Does anyone know what causes this and what is the best way to removing using post processing. Thanks! Treaks
  • John Hill May 31, 2008
    Purple fringing on pics when using the 1.5x converter on Fuji S5700. More pronounced if the background is sky. As in birding photography.
    Can this be corrected with a filter on the lens?
    John Hill
  • 14 Answers
I use paintshop pro v9 to remove purple fringing. It has an option under ADJUST/PHOTO FIX/CHROMATIC ABERRATION
it really does a great job even in automatic mode!!! Im sure the latest vs 11 will work even better!
This is common with zoom lenses. very difficult to find any optics that does this. maybe some cameras will remove that within the camera itself.
Posted on Nov 17, 2007
SOURCE:
Remove the purple rim around my pictures?
That is known as 'purple fringing' and is usually the result of the sensors and/or the lenses in your camera not being able to handle higher contrasts or over-exposure. Scientifically it has more to do with the how the camera sensor responds to the available light spectrum. (see: https://en.wikipedia.org/wiki/Purple_fringing) Have you notice it is generally more pronounced where a very bright (white) area meets a high contrast (black) edge (like a bright sky behind a dark or shadowed object)? Best way to avoid is to be careful about the relative light levels exposures when framing the shot---or using a UV filter. There are many photo editing programs which can help eliminate purple fringing in post production. Have a read through: http://www.photoforbeginners.com/news/tutorials/how-to-remove-purple-fringing-from-your-photos.
Nov 09, 2014 | Fuji FinePix Cameras
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Test chart tamrom
Front and back focus tests are good to run. You need to do it for each prime lens (fixed focal length) you have, and at your favorite focal lengths for wide angle zoom lenses too. That means on this 17-50, you would pick wide 17mm and zoomed in 50mm, and several others between. If you pick 25mm and 35mm to test, you would end up with 4 potentially different adjustments. These would apply only at 17, 25, 35 & 50mm. If you shoot at say 20mm focal length, and assume it's the same as 17 or even 25mm, you may be wrong. Too much back or forward focusing is a problem with the camera body usually - not the lens.
I'd pay attention to the lens. Look for cloudiness on the edges of the glass, scratches and fungus on glass, wetness or oil on the aperture blades, specs of dust inside the lens, etc. All of these things take away value from the lens, as they can adversely affect the image or shorten the useful life of the lens. You check these things by looking directly through the lens (not on the camera) and look at a dark background - then a light colored background to help show dirt and dust inside.
The only other thing is to look at actual images taken with the lens. Enlarge the pictures to 100% or more. Look for fuzzy edges, purple fringe edges, colors. You will see all of these issues the more you zoom in. You have to decide what it acceptable to you and what is not. Expensive lenses capture great color, are very sharp and have minimal purple fringing on hard edges (high contrast areas) in pictures.
Jan 30, 2012 | Tamron Test Chart For Tamron Af 28200mm...
I get blue fringing when attached to my Tamron 70-300mm zoom
Add-on "universal" supplementary lenses like yours are not optimised for any one make and model of lens. Distortions and fringing are totally normal at most lens settings.
Your lens is a useful and cheap add-on, but you only get what you pay for. Remove the fringing in post-processing.
Apr 13, 2011 | Sakar 2662T Lens Converter
What would happen if the sky was purple instead of blue?
We might still call it blue. Color is refracted light.
Feb 28, 2011 | Nintendo Game Boy Color Console
When taking pictures there is a color displacement of some sort. Leaves like bright purples and pinks shadowing images.It is worse in lighted areas, the more sunlight/bulb light the worse the coloring...
The term for an out-of-focus purple "ghost" image on a photograph is "Purple Fringing."
This is fairly common in Digital Photography.
In order to minimize instances of purple fringing you may incorporate the following:
Avoid shooting with big aperture (Small /f number) in high contrast compositions.
Avoid overexposing highlights (e.g. bright sky behind dark objects).
Shoot with a UV/Skylight Filter or a Circular Polarizing Filter. These protect the lens and also help to Get bluer skies and cut glare off reflective objects.
You could also use Post-processing to remove purple fringing by scaling the fringed color channel. This can be done in an image editor like Photoshop.
These suggestions will help in minimizing the instances of color displacement for you.
I will look forward to your feedback and positive rating.
Sep 11, 2010 | Sony Mavica MVC-CD500 Digital Camera
The picture suffers from colour fringing
either the color wheel has lost a segment or the colorwheel index needs to be adjusted in the hidden menu using the color ramps test screen.
Jul 20, 2010 | InFocus ScreenPlay 4805 Multimedia...
My PS2 will not read a purple sided game that my
I had same problem, you need to have the laser cleaned.
Dec 04, 2009 | Sony PlayStation 2 (PS2) Console
Pink Edges in Photos
It is called 'purple fringing' or chromatic aberration. It is quite common with digital cameras, especially those with small sensors. Sending the camera in for repair would not help at all. It can be removed, quite labouriously, in photoshop. Usually it is very seldom so obvious that it would require corrective work. When it is, it is often only in a small part of the image making it not that time consuming to fix in photoshop.
Sep 14, 2005 | Canon PowerShot A70 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
88 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
