The part that sticks out of the back of the tv that you attach your cable to is missing on my Sharp tv...can I replace this part easily so I can use it again?
  • 1 more comment
  • hrachaelh74 Sep 01, 2008
    Thanks so much...how much does a soldering tool run and do I have to take the back of the tv off to do this?
    I have the little red, yellow and white circles on the back of the tv and the front and I have a digital (dvr) box from Comcast. Is there a way to rehook everything without doing the above? Thanks!
    I don't have the remote for the tv...guess I should get a universal before trying this?
  • 927 Answers
Good Day, hrachaelh74;
Yes you can do this the part is called 'RF CONNECTOR'. Can purchase any radio shack or electronic store/service center. Just make sure you a good soldering tool.Good Luck, big IRISH.
Posted on Sep 01, 2008
  • 1 more comment
  • MICHAEL MULLINS Sep 01, 2008
    Yes, you will have to remove the back of the TV. Make sure the TV is unplugged from the A/C outlet. You may have to remove the device that the RF is connected to. BUT if you have video inputs on the TV use that option. It will safe you all this concern. Do you.... have a box? Let me know, Good Night, big IRISH.
    Good Day, hrachaelh;
    Yes, those little circles of colors are video inputs for the TV and the 'color circles' on the BOX are outputs. So, get a set of cables, red, white and yellow, you probably have some from a VCR or DVD player, connect cables from BOX to TV, keeping the colors matched up. Now use the TV's remote, not the Comcast remote, and look for an input button on the remote> push it until picture from BOX appears. Each company has different names for input some say video, input, etc.
  • MICHAEL MULLINS Sep 02, 2008
    Good Day, rachael;
    Your TV's front panel buttons may have same buttons of concern, look for same. good Luck, big IRISH.
T-con board or maim Board issue? Disconnected T-con from the main board and got back light! sharp lc-55le55ou
Hook the Tcon cable back up and do this. With a program running on the TV, shine a flashlight in the screen. If you can't see movement from the program, then the Tcon board is bad. you can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Sharp Aquos Televison & Video
How can I jail brake it
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...Missing: jailbreak
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into just about any TV with HDMI® and start streaming your favorite content. ... (for remote); USB power cable + wall adapter; Get started guide; Special content offers.Missing: jailbreak
Roku Streaming Stick channels - YouTube
Dec 15, 2015 | Roku Streaming Stick HDMI Version
DRZ250 2007. throttle sticks momentarily as you you throttle on. Cables lubed and move freely. Throttle tube action free and easy. Think problem linked to Carb internals. sticking slide???
To eliminate which is causing the sticking:
Remove cable lug from throttle tube and roll throttle back and forth with 1 finger. It should roll very easily.
Now with cable still undone from the tube, grasp the cable lug and pull it straight out and slowly feed it back into the cable sheath. If it sticks, then remove carb and top of carb. Leave slide attached to cable and pull the cable out by the lug like you did before. Watch the spring compress and extend as you slowly let it back out. if it sticks again this time, you mostly likely have a single broken strand that is snagging on the coil shaped section of the sheath. If not, then you have an issue with the slide not freely traveling in the tracks, or the main jet needle not smoothly reinserting into the hole of the main jet.
Back to the very first test. If the throtle tube stuck at any point with the cable unattached, remove the rubber grip and check for cracks or breaks in the plastic throttle tube. With the rubber grip removed, and tube still attached roll it again with one finger. If it moves easily, take a look at the large round part of the grip. was it rubbing on the housing of the brake reservior?
let me know what you find, well get it figured out. - astrawoid
Dec 10, 2010 | 2005 Suzuki DR-Z 250
I need a part number (or the part) for the Sharp TV, model number 32C241. I think the part is JBTN-0132GJKB but I can't correlate the number with a picture to be sure. The part I'm looking for is the...
I am unable to locate of picture of that part either but when Sharp says "power button" the on-off plastic push button is what that means. The cheapest I found it was on the mcm electronics website.
Aug 17, 2010 | Sharp 32C241 TV
My Sharp 56DR650 LED Blinking
Check the number of time it blinks. that is the error code and compare it with the problem listed in the owners manual. see www.fixurtvs.com. The code 32 means the color wheeel is getting stuck. You can try to clean it and put it back or look for a replacement. Repairs should cost you 350 to 450 at shop and 150-250 at home subject to the availability of parts. Cleaning it just a stop gap measure and not a lasting solution. dont worry if the wheel opens up into two with black dust inside. Just clean it put a drop of light machine oil like sewing machine and put it back. there will be hum but the wheel works for months and maybe a year. it varies from tv to tv and quality of your workmanship.
Jan 24, 2010 | Sharp 56DR650 56" Rear Projection HDTV
My Sharp Flat Screen Tv Model LC32SB24U has a USB input recepticle in the back. I bought a usb cable connected it to my computer and nothing happens? what is it used for. My tV came with NO disc for...
The USB entry is mostly used for a foto slide show.
Please read the owners manual before plugging in any kind of USB sticks or other cable's in a TV set.
It can damage the set when there is a ground connection between some devices.
Nov 12, 2009 | Sharp LC-32SB24U 32 in. LCD TV
65dr650 color wheel
It is in case next to the lamp. Its thin cable sticks out from the case. You will to open the back panel of the TV, check for cables, remove screws for the base on the right, then pull out the base out. You will have to be very careful removing screws and gentle when replace the color wheel. Hope this helps.
Feb 19, 2009 | Sharp 65DR650 65" Rear Projection...
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
Cable plug in back forcefully removed.
The cable conmnector (F-connector) attaches directly to the tuner board. There is only the center connection and the ground connection. This is a simple repair for a shop but requires a bit of practice (you can't melt the inner insulator). The part costs around $2. Check with a local shop for their repair charge.
Dan
Apr 07, 2008 | Sharp 25VT-J100 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
