Question about Sanyo DS24425 24" TV
"reset button" Yesterday I was able to access up to 73 channels. Today I accidently pressed the "reset" button, the tv flipped through the channels for a minute, and now I only get 13 channels. Help!
  • sammybaby123 Sep 01, 2008
    You have to go in and manually add all those lost channels yourself. Go to "menu" and under "channel search" or "add channels" you must press in each individual channel (say "16") and then press the "+" button until the screen says "added".
Eat a willie with mayonnaise
Posted on Sep 01, 2008
Channel flipping autom.
you can ask to the cable company. However if you need the channel go to the MENU in TV, AND Auto program for add the 73 channel.
If you doubt, download from www.retrevo.com
God bless you
Jul 17, 2013 | Orion STV2763 27" TV
No sound on iplayer on tvonics z500hd
Workaround procedure to get this to work 1. Go to BBC1. 2. Go to the Guide and select channel 200 - BBC Red Button. Press OK. 3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds. 4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index. 5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound. 6. Press the RED button to get into the Red Button Menu. 7. Wait a few seconds and then select the BBC iPlayer. I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound. I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method. Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
Mar 29, 2013 | TVonics Televison & Video
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 16, 2010 | Haier HTF20 20" TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Worked yesterday - won't work today
Have 2 remotes 1 to turn tv on and off and the other to change channels.
All I had to do was press INPUT......I knew it would be easy!!!!!!!!!!!
It took me all day to accidently press INPUT!!!!!!!!
Thanks from a not so computer savvy gal........
Jun 16, 2009 | Insignia Televison & Video
Sanyo DS24425 24" TV Logo
288 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
