Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Turn signal probs
The right turn signal indicator light stays on. the right rear turn signal stays on and it blows the acces. fuse in the fuse box after riding it for awhile. then i loose the horn,turn signals,cruise,brake lights, tack and speedo.
    Genius:
  • 2,028 Answers
This is going to be one of three things, and you should check them in this order, 1- you have a loose connection, bad/broken ground wire, or an exposed/bare wire on, around, or in line with the rear signal that is staying on. It's common for the wiring insulation to rub through and short at the bend where the signal wires go through the signal mount and run down the rear fender strut. 2- the switch on the bars is sticking or malfunctioning, however, this is less likely because it usually causes both signals to remain on. and 3- the flasher relay has malfunctioned and needs replaced. I'll bet that this is a bare wire, so start by tracing the signal wires for the right side. If you don't find a bad wire, then replace the relay. Let me know what you found out.
Posted on Sep 01, 2008
Alpha Romeo 156 My Left hand indicator light stays on continually, does not flash. and when I turn the hazard light switch on both indicators continually glow.
Generally speaking, symptoms of a bad or failing turn signal bulb are usually the culprit...in your case, either it's the front left or rear bulb. Varies for different vehicle makes...common signs include:
  1. turn signal light staying on solid
  2. or blinking very fast
  3. or either sides of the bulbs stop blinking altogether.
To test this, make sure you reconnect everything you disconnected.
Turn the left signal light on; go to the front of the vehicle, is the turn signal bulb illuminated? If it lights up, even though it is not blinking obviously the bulb is okay. If it doesn't, replace it- problem solved. You'll do the same procedure for the rear turn signal Is that lit up? If not replace the bulb and the problem is solved.
Another common failure is when the turn signal blinks really fast, same procedure as mentioned above.
If both bulbs for the left side and right side illuminate but don't blink, the problem is in the steering column turn signal switch.
If the left or right side blinkers don't work properly at all...then check the integrated hazard warning/turn signal flasher relay- that may be defective; again, that's usually the case if both sides of the signal light don't work.
If you are blowing any fuses related to the flasher system, you have an electrical overload in the turn signal circuitry.
Feb 12, 2017 | Cars & Trucks
Turn singles and hazards are not working on my 2001 deville
I would replace the turn signal hazard combo switch.
Nov 28, 2016 | Cars & Trucks
2010 chevy equinox right rear turn signal doesnt work, replaced bulb and still the same. front works, is there a fuse for the rear light and where is the fuse located.
RT/SIG fuse #11 15amp - I/P fuse box . Fuse Block - I/P
In the center of the instrument panel, beneath the right side of the radio, in back of the right side console access panel.
This fuse is power to the BCM , When you put on the right turn signal , this is a voltage signal to the BCM . With logic ( programming ) the BCM then controls the turn signal !
Turn Signal/Hazard Lamps
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
There could be a DTC- diagnostic trouble code stored in the BCM pointing to the problem ! I suggest you take your vehicle to the dealer or a ASE certified repair shop that has the diagnostic tools to find the problem . Just so you don't waste your money replacing parts that don't fix it.
There could
Dec 14, 2012 | 2005 Chevrolet Equinox
Rear night time lights will not turn on.
the wire that he hooked up is prob grounding out n blowing fuse
Dec 15, 2011 | 2000 Buick Century
2003 Chevy Silverado When I apply the brakes the
I had an issue like this one on a 2007 Colorado. I assume you mean the turn signal indicator inside the truck lights up. It was a bad bulb. think it was the turn signal bulb on the side that is lighting up. As for the gear indication being dim there is more than one bulb that lights them up and one may have blown. I hope this helps.
Jul 15, 2011 | 2003 Chevrolet Silverado 1500
Right turn signal blows fuse. replaced speedodemeter to correct problem and it is still blowing fuse. what else could it be. all wiring is good.
I don't have a wiring diagram for your '05 FLHRS but since the early '90's, Harley has used a turn signal cancelling unit to control the turn signals. Once you press a turn signal button, the turn signal controller activates the signal for specific lenght of time then it cancells the signal. There is a wire that comes out of the plug on this cancelling unit that goes to front turn signal and rear turn signal on each side of the bike. If you are blowing a fuse when the right turn signal is activated, I would suspect a short somewhere along the wire that comes from the turn signal cancelling unit going to either the front or rear signal light. The cancelling unit is a "black box" that is about 1 1/2 inch wide, about 3 inches long, and about a 3/4 inch thick. It may be located between the tanks on a split tank model or under the seat on other models.
Nov 06, 2009 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Right turn signal stays on will not flash left works.2001 jimmy
its your blinker box.. all major lights run through there
Aug 04, 2009 | 2001 GMC Jimmy
Rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
May 23, 2009 | 2005 Chevrolet Silverado 2500HD 2WD
1997 dodge avenger turn signal probs and location
replace the turn signal switch it self, mine did the same thing with the left turn signal, put in fuse and it will continue to flash... went to junk yard pulled one out of a 97 avenger just like mine, swapped them out and now it works fine. looked to be like some corrosion... to repace: 3 screws under columb, 2 screws on side of signal switch (black plastic side). unplug and replace
Mar 20, 2009 | 1997 Dodge Avenger
Indicator lights no longer blink its one solid light
Im Not Totaly Sure But Most other Makes & Modles Ues 2 Seperate Signal FLASHER Units
Your Owners Manual Should Show this As Turn Signal "FLASHER" Located At or Near Fuse / Relay Box This is ASUMING you have Checked The Fuses and Relays
Feb 09, 2009 | 2000 Mazda Protege
Lands Phones Logo
415 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
