Question about Garden
Ryobi water blaster hose
1. Where would I go from Papakura to get the hose fixedG.
2. can I get a new hose attached to my existing fixings or does it mean complete hose fittings and all?
  • Farmgoy Mar 25, 2009
    Thanks, appreciated your well thought out answer.
3 Suggested Answers
SOURCE: I set up a drip system years ago and now am
It's not really a solution-it seems there are two sizes OD (.700", .620") both called 1/2" tubing. The appropriate sized fittings must therefore be used
Posted on Mar 22, 2009
wmpcs
  • 100 Answers
SOURCE: 1. Decrease in pressure. Can't clean deck
If the pump is leaking then it is going to either be the water seals or o-rings on the inside of the pump. If this is the case I would recommend just tossing the unit, what it would cost to rip the machine apart and replace these items would be more than what the machine is worth.
Posted on Oct 25, 2010
My heat stopped working in my 1992 Cadillac Eldorado what is the problem...
1.COOLING SYSTEM POSSIBLY BLOCKED . SOME TIMES BACK FLUSHING USING A WATER HOSE.
2. FLUSH RADIATOR
3. REMOVE THERMOSTAT
4. REMOVE HEATER HOSES FROM HEATER CORE AT FIREWALL
5. PUT WATER HOSE IN WHERE YOU REMOVE THE THERMOSTAT
6. FLUSH UNTIL CLEAR WATER COMES OUT
7. IF YOU HAVE AN OLD WATER HOSE LAYING AROUND, CUT ONE END OFF AND USING A SMALL SCREW CLAMP ATTACH IT TO ONE OF THE COPPER PIPES, NOT TOO TIGHT
YOU MIGHT DAMAGE IT. THEN TURN ON THE WATER AND FLUSH OUT THE HEATER CORE, UNTIL WATER IS CLEAR.
RE ATTACH ALL HOSES INSTALL NEW THERMOSTAT , REFILL WITH ANTIFREEZE.
Nov 08, 2014 | Cadillac Cars & Trucks
Culligan n8 black hose fell off and water was flowing out until i turned off the valve how and where do i re attach thx
If the "black hose" is about 1/2" in diameter it attaches to the drain elbow on the left side of the valve. Use a hose clamp, cut some of the drain line back (about 2") slide it back on the drain elbow and clamp it on the elbow.
If the black hose is 3/8" it attaches to the fitting on the salt tank, which attaches to the float.
If it broke because it is brittle I would go to any water treatment dealer and get a new piece of "brine line" to replace it.
RJ
Oct 10, 2011 | Culligan Under Sink Water Filter
I want sb0220 sound driver
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
This is the latest driver update for the Sound Blaster Live! series of audio cards only for users running Windows 95 and 98. This release includes updated version of Surround Mixer 1.0 and AudioHQ, 1024-voice software MIDI synth for Sound Blaster Live! (Option to select up to 1024 software voices), and improved support for Occlusion and Obstruction effects in EAX2.0
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10005159.html
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight.
http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
Jun 12, 2011 | Creative Labs Creative Sound Blaster Live...
Existing gas line fell aport. Have new hose but need gas line routing for Ryobi leaf blower.
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
HERE IS THE PARTS BREAKDOWN OF A RYOBI/MTD/RYAN ENGINE.....THE BEST THING I CAN DO WITH OUT PHISICALLY SHOWING YOU. HOPE THIS HELPS AND GOOD LUCK
Nov 23, 2009 | Ryobi Garden
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
Slow water delivery into machine
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Q - My washer fills slowly with water, what can I do ?
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Mar 14, 2009 | Fisher Washing Machines
Ryobi 725R fuel filter; How is it re-mounted? Fuel line is soft and weak > tears easily. I am replacing the fuel lines and need to re-mount the fuel filter into the tank. It seems next to impossible to get...
after you insert the fuel line through the tank and install the filter. take some WD-40 and spray the hose. now from the bottom of tank the pull on the hose. and just keep pulling on it till it comes through all the way. then slide the little white washer back over the hose and seat in place. this should do it for you. they are a royal pain in the **** to work on. numerous brands of string trimmers have these top mount tanks. a new tank with hoses already assembled is about 45 bucks with shipping. much cheaper to fix it yourself.
Mar 11, 2009 | Ryobi 15" Electric Factory Reconditioned...
How do you get the water pump and fan disconnected from each other on a 1997 Dodge Pickup truck 318 motor?
you need a special tool , a fan nut tool , it's like a 1-1/2 " ,actualy a little smaller , i use a 1-1/2" wrench and smack it with a rubber mallet , but there is a tool for it , i think checkers auto has a loan -a-tool program , but to buy it is expensive , it is normal threaded - counter clockwise is off . a special tool holds the 4 bolts on the pulley and the other part of the tool fits on the big nut . sorry i can't fix ya , cuz who has a 1-1/2" wrench or the special wrench in there home arsinal .
J5
Jan 22, 2009 | 1999 Dodge Ram
Bissell proheat, not sure of model number no water will dispense
Ran in to similar issue except mine would not spray soap or solution through the floor cleaner but would work through the upolstry cleaner.
I found that there were 2 problems as follows:
1) The heater was clogged with mineral deposits and old soap that I had not cleaned out on a previous use.
2) The Valve that attached to the trigger sticks. (I am currently looking for a new valve)
Since you have soap and no water I your problem probably exists in the bottom of the unit. There are 6 screws to take off the cover.
You will see a hose that come from the soap despenser. It leads to the pump which is located in the front left corner of the unit. You can also trace the water hosed in and out of this pump. Since the hoses are clear you should be able to see any clogg. There is a hose that leads up the handle to the valve and then a hose that comes back down the handle (through the wheel opening) The hose that comes back down from the handel leads to a splitter which devides the output to the two jets.
Once it is apart it is pretty simple.
Hope this helps!!
Nov 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Garden Logo
727 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
