Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer has fried wire
My Whirlpool dryer recently stopped working all together mid cycle. The control panel was very warm to the touch and there was no light or response to any button press.
When I took off the back panel by the wire I saw this:
The black (before burning) wire has totally fried. ...It seems like i could just strip the wire back and re-connect the wire, but I dont want to risk a house fire if this happened again. Any thought to what could have caused this?
The outlet looks like just a standard 220v outlet and doesn't show any signs of being burned or shorted.
Thanks,
Thad
    President:
  • 1,462 Answers
This is quite a common thing to happen and is caused usually by the connection coming a bit loose causing a high resistant joint.
carefully clean up the joint and remake the connection
Posted on Sep 01, 2008
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
Dryer stopping mid cycle
You have to test several parts, common causes are defective termic sensor, or fault program control.
Post model number for more details
Jun 01, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Whirlpool Dryer has stopped working. Power cord is
  1. If the tumbler won't spin when it operates, unplug it and try to move the tumbler by hand. If it won't budge, then something is jammed. If it turns with no resistance at all, you may have a problem with your drive belt. If it turns with consistent, minor resistance then the problem may be electrical. Follow the instructions of your user's manual to remove the tumbler so the belt drive and motor are visible. Inspect the drive belt. If it hangs loose, it needs to be tightened. If it is frayed or has worked its way up the drive shaft, it should be replaced. Try to turn the driveshaft leading from the motor by hand. If it won't budge, then your motor is seized and needs to be replaced. If nothing is wrong with the belt or the motor, then the problem is in the control circuit. It may be damaged, preventing the motor from engaging.
  2. If the dryer stops working mid-cycle and will not respond to any of the control functions, unplug it, empty it of clothing and pull it away from the wall. Remove the service panel on the back and open it. Be mindful of smoke and the smell of burnt plastic; these are good indications that something carrying electricity has just died. This particular model of dryer is notorious for its electrical plug and power block, which should be the black box near the bottom in the back. If there are any signs of charring, melting, or discoloration, the power cord and block are your culprits. These can be replaced with a new power cord and terminal-connection wire kit obtained at any hardware store. If there is no indication of electrical damage, the problem is likely the control circuit set underneath the control board on the face of the dryer. Such boards can't be fixed, only replaced--a task best left to a certified repairman.
  3. Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  4. please comment on these solution staying on how it help.
Dec 21, 2010 | Whirlpool Dryers
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
Whirlpool estate dryer stopped working mid-cycle and will not turn on at all now
The thermal fuse is bad . Located on the blower box , a small white piece , with 2 wires attached to it . Have to remove the front panel to access .
Aug 09, 2009 | Estate Dryers
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer stopped working in mid-cycle
more than likely a thermal fuse has blown ..i believe on that model you pop the clips holding top down element is on rear wall of dryer thermal fuse has 2 white wires going to it and is mounted on side of element the big thermostat on top and the fuse come in a kit and should be changed together
Jul 20, 2008 | Dryers
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LEQ9858P Electric Dryer Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
