Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator is stalling
Our generator is stalling out after about 30 minutes. It is skipping also. I had inadvertantly run it with SAE 30 non-detergent for about 30 minutes, then turned it off and changed it to SAE 30 heavy duty.
  • jforgette Dec 26, 2008
    I have the same problem, engine sputters out and often dies after about 20 minutes of running fine, except mine is an after-market propane conversion, so none of the gasoline fuel remedies offered seem to apply here.
    The engine is a 10hp Briggs, electric start. I'm going to check the low-oil sensor as suggested tomorrow... otherwise it could be something in the ignition/spark system? Or maybe the worn generator brushes... I'll check them all and see...
    Novelist:
  • 72 Answers
My answer:
Not knowing your model # and how old your generator really is - as related to TOTAL RUN HOURS - I can only give you several possibilities of what the problem might be even though I don't know the make & model and what the rated WATTAGE output is.
I also don't know what LOAD you are putting on the Genset or at what RPM you are running the engine at as to half throttle or full throttle setting?? I take it that it's a Briggs & Stratton 4-stroke single cyl, or is it a Honda 4-stroke single/twin cyl engine?
Since it runs good for 30 mins, and then starts to cut out - I doubt that the OIL is a problem even though you ran straight 30 weight - seeings most small engines run 10-30 weight oil as a rule.
I seriously doubt you did any damage to the engine at all unless it was ran low on oil - in which case it should have a LOW OIL cutoff switch mounted in the lower engine case close to the CHECK OIL port.
If the LOW OIL switch is working properly and adjusted properly then you shouldn't be getting cutout unless this switch is mis-adjusted. (ie: mechanically set too low as then when the oil level is indeed at it's proper level the switch would be already shorting out to ground) (See your operators manual for proper setting)
A way to check for proper operation is to temporarily disconnect the (usually) BLACK wire from the LOW OIL switch when the engine starts to cut out. If the problem goes away completely then the LOW OIL switch is either mis-adjusted or else it is going bad from vibration. (Again see your operators manual for proper adjustment and/or check out procedure)
Electronically this LOW OIL switch should be the only thing that would protect the engine from damage should the oil level fall below recommended level. Other then that it may have an electronic REV LIMITER if it's a bigger and more expensive model, but usually not.
I doubt the Maintenance-free Magnetron® electronic ignition is at fault, but could be weak and going bad. Always a possibility, but I would 1st rule out everything else first. Since the Genset runs for 30 mins and then starts to cut out I would look more for like a fuel vapor lock (partially closed or clogged gas cap vent), a possible dirty fuel filter, possible water moisture in the gas tank or in the carb bowl, possibly dirty carb in general along with it's dirty Float Bowl, Float Pin, Float and Needle Valve, and any Adjustment Screws that go Into the Carb Body. That covers everything from a fuel standpoint.
You do know that all Gensets should be started and run for at least 10 mins every 30 days - right? If you didn't know this - now you do! Every good operators manual should state this.
It just doesn't sound like it's starving for gas unless it's building up a (vacuum) or vapor lock in the gas tank.
Having covered everything from an Electronics/electrical standpoint engine wise - there is only one other thing left Genset wise.
What it really sounds like to me (and I personally HAVE SEEN this happen myself firsthand) is that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
It has to be one of the scenarios listed above.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Best regards and thanks,
Frank
Posted on Sep 01, 2008
  • Frank JR
    Frank JR Sep 02, 2008
    Hi Mike,
    Thanks for the feedback on the Genset.
    Subaru engine should be pretty straight forward unless you got a bum
    engine to start, but I doubt that very much, and I hope for your sake this is not the case. 30 hours
    is nothing - depending on how it was broke in when brand new - all gas aside here. Again -
    following the owners manual, as every engine is slightly different.
    As to what you said about the gas tank, and emptying it out and then
    refilling it, etc and then the problem starting right after that -
    that's the KEY POINT right there!!
    Now I know for sure it's Carb related as to the Float, etc.
    The gas tank fuel line does have an in-line fuel filter correct? If it
    doesn't you definitely need to add one for dirt protection!!
    Depending on how you emptied the gas tank (tilting the Genset on end
    maybe?), and what was inside it after you refilled it (as I have no
    idea just how clean your gas/fuel is over there to begin with - all
    water in the gas aside), you may very well have gotten either water
    moisture or dirt in the Carb bowl, or else dirt in the Float Pin, Float and Needle Valve assy, or any Adjustment Screws that go Into the Carb Body.
    Worse case is that you misaligned the Float itself somehow inside the
    Carb Float Bowl, and now the fuel level inside is either running up too
    high or else too low and causing either a TOO RICH or else TOO LEAN a
    fuel mixture - thus causing the engine to maybe run way too HOT.
    Hopefully the engine is not trying to seize up on you!
    It's hard to say unless the Carb first is broken down, checked for
    proper Float action setting, and/or cleaned out accordingly if dirt is
    present in the bottom of the Float Bowl.
    If all looks good there Carb Bowl wise then you will next need to check the air/fuel mixture Jet Adjustment Screws.
    Let me know if you need that adjustment procedure after you first check
    everything else out I sent you previously and what I sent you here
    today?
    Keep me posted and I'll follow up as well.
    Best regards,
    Frank
This is jforgette, my neighbor's generator was almost brand new, so I didn't think the worn brushes applied. But we tried the low-oil shut off idea. He thought the oil was full enough, but I told him to fill it to beginning of threads at bottom of fill hole. It only took about 1/4 cup. But... believe it or not, THIS SOLVED THE PROBLEM of dying after 20 minutes of running.
So Frank had the solution for me... thanx!!
Posted on Jan 02, 2009
Frank,
Thank you for the quick, and extremely thorough response. I failed to provide any background information as you noted. The generator is a Coleman Powermate 5000 Running Watts 6250 Maximum Watts 10 HP Subaru OHV/OHC gas engine with 5 gallon gas tank.
It only has about 30 hours on it. I got it from someone who brought it over from the Mainland (I live in Saipan near Guam). He brings generators over periodically and sells them (saves the buyer a little on shipping), as the power situation here is characterized by frequent outages. Anyway, he used this one for about 6 hours, then sold it to me and installed it.It worked fine until this past weekend. Besides the oil change, I did fill it up with gas at the same time (I poured everything out of the gas tank perhaps there was some water in it). After that is when the problem started. It skips or misfires?, then dies after about 30 minutes as I mentioned. I try restarting it but it stops after shorter periods of time, about 15-20 minutes.
Anyway Frank, I will go through your list and see if I can remedy the problem.
Again, Thank You for your prompt and very detailed response.
Mike
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What oil to use?
what is recommended in the owners manual if not sure try Google Make model and manual
May 18, 2015 | Garden
What is an alternative to sae-30 non-detergent oil.
A two stoke oil is a non detergent oil and is mixed with the gas for two stroke engines. If you are looking for an oil to add to the crankcase of a four stroke engine, you are better off with a detergent oil, the detergent and additives are make to keep your engine clean by attracting the particles in the engine crankcase.
Jan 26, 2015 | Garden
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Honda 2500 PSI Gas Pressure Washer
Correct oil for this generator
This all depends on what type of climate you live in. Most small engines that (do not) have an oil filter uses SAE 30 motor oil. This oil has a detergent in it that helps clean your engine.
Dec 01, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
I have a gen power gx400i generator 4.0kvaor 3.0kw, 4stoke single cylinder air cooled.I'm not sure what type of oil is needed?
Hi and welcome to FixYa, I am Kelly. Oil changes are supposed to be every 100 hours. You should use SAE 30 WT (non detergent) oil for at least 3 oil changes / 300 hours then 1 cycle of HD-30 WT oil as it does a bang up job of cleaning things out of the crank case and prevention of the oil rings from sticking on the piston skirt. I have made this recommendation for at least 30 years and never had to rebuild a home owner or RV type engine in a unit where it was known the owner did this cycle of oil changes in a generator. (Vavle work yes.. engine bearing and piston rings no!) .. The brand does NOT matter as long as it is SAE 30 WT oil. Lubricants can not get the SAE rating if they do not meet the standards. Just do NOT use a synthetic oil in it.
Kelly
Nov 29, 2010 | Coleman Powermate Premium Plus 6250W...
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
What kind of oil should i use for a 2004 Chrysler town and country?
Driving conditions / oil
(Note all oils are NON-DETERGENT)
City hot / SAE 20W - 50
City warm / SAE 10W - 40
City cold / SAE 5 -30 or 5W-40
Rural hot / SAE 20W - 50
Rural warm / SAE 10W - 40
Rural cold / SAE 5W - 30
Brand does not really matter as the SAE designation makes them all the same other than a few manufacturer specific additives i.e Techron ect.
Feb 14, 2010 | 2004 Chrysler Town & Country
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
839 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
