Question about Palm IIIe Special Edition Handheld
Hot sync operation cancelled (8001)
Cleaned the contacts, rock the device and use the lowest speed. Log says that while determining hand held configuration, the hot sync was interrupted. The palm handheld says identifying user. Have closed all application even in the background.
    Master:
  • 473 Answers
Try replacing the cradle or if you can install Palm desktop on another computer and try synchronizing on it. This is usually a sign of a week cradle or COM port on your computer.
Posted on Sep 12, 2005
Masport log splitter how do you rewire a 7tonne pressure log splitter
Make sure the device is unplugged from the 240 VAC power source.
Connect the 240 VAC line and neutral wires to the momentary switch. Examine the motor wires to determine line and neutral.
This log splitter is equipped with a control system that requires to be operated by both hands of the user - Left hand controls the
hydraulic control lever while right hand controls the pushbutton
switch. The log splitter will freeze upon absence of either hand. Only
after both hands release the controls, the log pusher starts to return
backward to the starting position.
http://www.masport.co.nz/common/download/556964/
Hope this helped.
Apr 20, 2014 | Tools & Hardware - Others
What is procedure to delete courses from the hand held devise? i have the SG4 Model. Thanks
Hello.
GPS receiver units are designed to translate signalsreceived from a satellite into recognizable graphic information using mappingsoftware. These systems are dependent on the installed software, butlike all computers they can experience problems up to and including unexpecteddeletion of the software. Because of this, many GPS systems have providedsolutions to some of the most common problems.
Operating System Deletion
If the hand-held unit does not display any functionality when activated,first try restarting the system. If the unit is a hand-held GPS, try removingand then re-inserting the batteries to reset the system. If the system still displaysno operating system, contact a professional for service. GPS software can alsobe bundled or purchased as part of a more comprehensive device, such as aniPhone or other smart phone. In this instance, it is possible that the softwarewas deleted from the system during a sync with a computer. Try re-syncing thedevice with the computer and ensuring that the GPS application has beenselected to be loaded onto the unit. If this does not solve the problem, thesoftware may be corrupt. Delete the program from the computer and download itonce again to the hard drive. Then, re-sync the newly downloaded application toyour device.Update Deletion
Occasionally, an error in the download or an error insyncing with a GPS hand-held can cause updates such as operating systemadvances, bug fixes and new map information to be deleted or corrupted. If thisshould happen, re-download the update information and sync it with the GPSunit. If update information comes in the form of an SD or other data card, thecard itself may be corrupted. Contact Thanks.
Sep 21, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Nov 02, 2009 | Palm TX Handheld
John deere 6400 4 wheel drive rock arm calibration
Yes but it has to be done in the dash in technition mode and all of the peramiters must be met.Engine speed,oil temp,ect.It's usually quicker to use the laptop.
May 07, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
I have a desktop dell runining XP software. I have a tungsten E hand held. I cannot get the contacts on the handheld to appear on the screen of the desktop. I just tried putting a new contact in the desk...
Try right click on the Hot-Sync icon, on the Taskbar and select Custom then select Address book and change the Action to Synchronise the files. You might have to use Windows Explorer to view your contact. I'm not 100% sure about this one but try it anyway.
Mar 19, 2008 | Computers & Internet
Hot sync will not complete
do some clean up: try to unistall and install the PDS, in th einstallation folder (usually c:\Palm u will find a user name folder,, inside this try to rename the backup folder or cut it and copy it somewhere else... let me know the news... good luck,
Sep 12, 2005 | Palm M100
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm IIIe Special Edition Handheld Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
