Question about ATI RADEON 9600SE128MB AGP Video Card Graphic Card
Only boot in safe mode with Vista
I try to install my ATI Radeon 9600se on Vista but i'm not able, i put the last Catalyst Driver, the last Motherboard Driver, when i turn on the PC, after a certain time, everything stop, i found if i change The configuration of CPU to AGP VIA for PCI to PCI, everything is ok but the Vista disable my video card with this way
  • Natas20075 Sep 01, 2008
    it's plugged in the video card ( ATI Radeon 9600se ) i don't have any other video onboard, The problem is, if i don't install the ATI driver and let the VGA driver everything is ok, except when i try to play game, that dosen't see which video card i got, so when i install the ATI Driver and i Reboot the PC, after the Welcome Screen, everything stop, my computer screen led start blinking, my keyboard stop responding and my computer don't do nothing, just freeze, so if i boot in safe mode, i can go in the computer system, hardware setting and i got 2 choice, i remove the ATI Video Card and start again or i change Controllor CPU to AGP VIA for Bridge PCI For PCI Standard PCI, thank you for responding
  • Roberta Smith
    Roberta Smith May 11, 2010
    Which connector do you have the video plugged into ?... you should be able to configure the bios to boot to agp first. if it doesn't find a video card there it will try pci and then onboard video.
    Robert
    Brigadier General:
  • 5,158 Answers
Recheck that you have the exact driver for that ati card including the correct driver for the operating system you are using. physically pull the card and confirm the model of ati card you have.
also consider installing just the driver and not the catylist program.
Robert
Posted on Sep 01, 2008
ATI radeon x600 128 mb video (Windows 7) driver
AMD's DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. But you can install ATI Catalyst Windows Vista graphics driver under Windows 7. Some features may not be available under windows 7 but it would be worth a try.
Sep 27, 2010 | ATI RADEON X600 Pro, (128 MB) PCI Express...
After instaling windows 7 my laptop did not pick up my ati radeon xpress 1250 ? what can i do to fix this
AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration
Apr 23, 2010 | Computers & Internet
Video is sporadic. Will work at first but if any
This Presario uses the 256 MB dedicated ATI Mobility Radeon X600 Video Display card according to the manufacture's website. Also this system came from HP with Windows XP or Windows Vista.
This may be a driver issue. Dealing with video driver issues can be difficult, but there are tools that can help.
If you are using Windows, boot into Safe Mode by pressing the "F8" key during initial startup. You will be presented with the option screen with many choices. Pick Safe Mode without networking.
After a second, Windows will boot into Safe Mode. From there go to the Control Panel and then to Add Remove Programs (XP) or Programs (Vista & Windows 7). Find the program(s) from ATI including
- ATI Software Uninstall Utility
- ATI Catalyst Control Center
- ATI Display Driver
These may prompt you to reboot after each removal, please select a manual reboot, or reboot at a later time.
Once all the ATI items have been removed, restart the computer. The system will reboot and it will load a generic driver. The screen may look different as the resolution has changed. This is normal.
Go to Softpedia and download Driver Cleaner to finish removing the drivers as they are still cached in the system. The link is here at http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Driver-Cleaner-Professional-15.shtml
Install and run this tool to finish the removal of the cached ATI Driver files. The screen may flicker, this is normal.
After completing the installation, restart the machine again.
When the reboot has completed go to ATI to obtain the latest driver here at:
NOTE: If you are using Vista, please make sure to obtain the correct driver for the 32 bit or 64 bit operating systems. This information can be found by right clicking on "Computer" in the Start Menu, then selecting "Properties". Once this is up there will be displayed the related information on your system. Look specifically for "System Type" and it will read "32-bit Operating System" or "64-bit Operating System"
(Windows XP) http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.19&lang=English
(Vista 32 Bit)
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.19&lang=English
(Vista 64 Bit)
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista64.aspx?type=2.4.1&product=2.4.1.3.19&lang=English
Select the Catalyst Software Suite. It is a large file and will require time to down load. Save the file to the computer. Once you have it you will need to run it. Installation will run then ask to reboot.
Reboot your system.
You may notice again the screen flickers. This is normal and the machine may also be slow for the first few mins after reboot. After a few minuets have passed you can adjust the screen resolution by right clicking on empty space on the desktop and selecting "Properties" (XP), then the "Settings" tab or "Screen Resolution" (Vista). The factory specs for the Presario are WXGA+ (1440x900) max resolution.
After adjusting resolution I suggest going to getting the latest version of DirectX (DX 9c Feb 2010) from Microsoft here at http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
This may also be a large file depending on what the installer needs and will require time to download.
This should complete the driver installation.
The Driver Cleaner tool can be removed now form the computer.
Feb 23, 2010 | Compaq Presario X6000 Notebook
Ati 9600se problems
I suspect that you are using too small a power supply. The display card uses a lot of power, to achieve the display rates. Try a heavier duty power supply
Oct 21, 2009 | ATI RADEON® 9600 SE, AGP Video Card
ATI Radeon X1250 for Windows 7
Note: AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration.
Sep 11, 2009 | Computers & Internet
ATI Radeon X1300 wont work with my Vista 32 bit
Try this.
Download the unified Radeon drivers from ATI's website... do not use Windows update. Get the Drivers Only package. for Vista 32-bit
If you can get to the desktop:
Uninstall the existing display drivers by using the remove hardware utility. Whatever they are... remove them. Reboot. Windows will try to reinstall the drivers on the next boot. If it allows you cancel the installation at any time during install do it. Run the downloaded package from ATI. Reboot.
If you can't get to the desktop:
Press F8 when booting and enter safe mode with networking. Download the ATI drivers from ati.com for Vista 32-bit.
Uninstall the display drivers. Reboot. Should take you to the desktop on the next boot so you can run the install program.
Jun 22, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
ATI Mobility Radeon X600 128MB Problems
Try restarting the pc in safe mode by tapping the F8 key while re-booting the computer. If the lines are gone it is the display driver.
You can get the correct drivers HERE from HP for your Laptop
Display problems support HERE
Jun 03, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
ATI Radeon mobility Graphics Card 9200 Drivers for VISTA
http://www.opendrivers.com/driver/240370/ati-radeon-graphics-card-driver-catalyst-7.11-windows-vista-x32-english-free-download.html
Dec 03, 2007 | ATI Mobility RADEON Graphic Card
ATI RADEON 9600SE128MB AGP Video Card Graphic Card Logo
71 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
