Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Cleaning before the self-clean - how much?
Just wondering if anyone could tell me just how much scrubbing I need to do before I put the oven in self-clean mode. The oven is nearly 2 years old and I've never cleaned it (ugh), so it's quite soiled. I was able to get a lot of it up with baking soda and a plastic scrub sponge, but there's more baked on the sides, top and back. Will the self-clean really get it all cleaned up, or shall I continue to scrub it myself? I want it to look new again!
  • pjcoop Sep 02, 2008
    Thank you! I appreciate your help and quick response. Looks like I have a bit more scurbbing to do...
  • Anonymous Dec 19, 2008
    Spend ten minutes reading this board.... you may need to replace a part when your oven stops working after using the self-clean. Just a heads up!
  • 125 Answers
If you get most of the big chunks out that should be good, make sure there is no tomato sauce etc on the porcelian as it can leave a stain. Don't forget to take the racks out as they will not slide well if left in durin self clean.
Posted on Sep 01, 2008
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Are there any special steps to self clean the oven?
Please follow the steps:
Run the self-cleaning cycle for your oven as often as you need to. It reduces almost any spill to a powdery gray pile of ash that can easily be wiped away at the end of the oven's cleaning cycle using a damp cloth. Make sure you have a window open during the process, to help keep smoke from sticking to walls and your ceiling. You may need to wash down the oven door and frame with a gentle cleaner to remove soil residue. Don't scrub the rubbery gasket that seals the oven door. Just rinse it with dish soap and then water. Don't use abrasives, or oven cleaners on the interior of the oven.
Thanks
Aug 29, 2009 | Ovens
Oven Caught Fire!!
Remove oven racks and look for two screws in the back on the bottom. Remove screws and lift out oven bottom. Do not use self clean.
Mar 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I need directions for GE gas wal oven
Call the mfr and let them know what you need. You can clean the porcelain of the oven. Just don't use too much elbow grease when scrubbing. Use a steel wool pad as easy as you can but hard enough to clean it. If you scrape of the porcelain, then it will be hard to clean from now on. It is like taking the pocelain off your teeth. It will catch everything coming and going.
Jan 29, 2009 | GE Ovens
Whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Dec 12, 2008 | Jenn-Air Electric Double Oven
How to remove smoke stain ?
Try a mild abrasive cleanser like Bon Ami or Soft Scrub and wipe clean.
Nov 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
85 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
