Question about Hitachi 43F300 43" Rear Projection Television
43F300 convergence My Hitachi 43F300 has a bowed green line in the picture. Can you tell me what Convergence IC's Part numbers that I need and also how to get to service mode to adjust the convergence?
    Genius:
  • 1,694 Answers
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Posted on Sep 01, 2008
There is a constant blue shadow and yellow bowing from the top of screen. Needs convergence circuit repair = replace convergence IC's, How is this done!!!
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2011 | Hitachi 43F300 43" Rear Projection...
The picture is bowed and you can see double and the color is wrong
convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
Oct 10, 2010 | Hitachi 43F300 43" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 43F300 43" Rear Projection...
43F300 convergence
convergence kit # x480306 , dont go into the service mode unless you know what your doing in there and what your adjusting./st.
Aug 22, 2008 | Hitachi 43F300 43" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Hitachi HDTV Model 46F500
replace convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 46F500 46" Rear Projection...
Blue shadow
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
127 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
