Question about Whirlpool AWM6100 Front Load Washer
How do I clean the filter
I have a AWM F/L 6100 and I have located something on the bottom right corner. I uncovered the circular cover and now what?
    President:
  • 1,462 Answers
Unscrew the circular cover, pull the filter out and clean it. water may come out.
Posted on Sep 01, 2008
How to replace ge rpwfe filter
I think on that model there is a long plastic cover on the top right hand corner with a tab in the front. Push tab and cover should hinge down to uncover the filter. Unscrew filter to left and pull forward. Reverse to install new filter.
Feb 25, 2015 | GE Profile PDS22MHR Bottom Freezer...
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I have a shadow on the screen in the bottom right hand corner what could the problem possibly be.
It sounds like something has fallen or crawled into your tv. Unplug unit and remove the panel on the rear bottom. Now remove the upper part of the rear cabinet if you cannot see the problem. You will probably find something on the lense blocking the light. This would be a good time to clean the lenses. Using a soft cloth and windex, spray the cloth then gently clean each lense using a circular motion. Do not wipe until dry as you may scratch the lense. Do not spray the lense as you will cover critical components with corrosive cleaner. Do not push hard or disturb any lense adjustments. Reassemble unit and your tv should look as good as new. Let me know how this works out. hardrocko@hotmail.com .
hardrocko
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Whirlpool AWM 6100/s - stopping mid cycle, not draining - unusual whirring noises, programme stops with '0' and '100' flashing on spin meter as well as paus and 'wash'
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Jan 26, 2009 | Whirlpool AWM6100 Front Load Washer
How do i clean the pump on my whirlpoll awo 3551
Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Jan 25, 2018 | Washing Machines
Not solution i need
The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground.
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Whirlpool AWM6100 Front Load Washer Logo
328 people viewed this question
Dan Webster
Dan Webster
Sal De
