Question about Saeco Royal Professional Espresso Machine
Descale and ventilate
Our machine is directly connected to mains water.
We have tried pressing the hot water button but get nothing but a slight hum. Someone suggested pump may be dead??
  • TJ Short
    TJ Short Sep 27, 2008
    Yep I got the same problem though I was able to fix my problem in 2 different ways. After having so many problems with SAECO machines over 9 years we gave up and bought a different machine.
    1. I released the air through the steam nozzle and then ran the hot water until the message went away.
    2. I bought a different brand machine AND we love our Sunbeam cafe series EM6910
  • Anonymous Oct 01, 2008
     i have the same problem, i have tried to relase the air through the steam nozzle but there is no air coming out
  • 515 Answers
I think your magnetic valve have to be replaced.
It can also be stop in the pipe to the rapid steam boiler in your machine.
/Mirran
Posted on Sep 01, 2008
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
Jan 27, 2010 | Gaggia Titanium Espresso Machine
Ventilate sign is showing and nothing works
Open the steam valve when the hot water words appear above the ventilate
Jul 21, 2009 | Saeco Royal Professional Espresso Machine
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
2 messages: descale, and ventilate plus no hot water only steam
descale you need to use special descaler not vinegar vinegar is not strong enought and remove calcium in little piece that might block elsewhere descaler melt calcium 1 part water 1 part descaler fill the water container start machine open side valve for few second turn it off wait 15 minute repeat untill empty after rince very good that stuff is corosif go in thr menue reset the descaler mode and voila !
THANKS FOR USING FIXYA
FROM MONTREAL
CANADA PIERRE
Feb 18, 2008 | Saeco Royal Professional Espresso Machine
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
