Keypad not functioning. When I scan my memory card, I found that 2 of
my downloaded themes are virus infected. Is this the cause of keypad
malfunction? please help, thanks.
Fix it to the pc, use the pc anti virus n scan it, everything will be fine. wen u plug the cable from phone to pc, select data mood. then u start scanning the memorycard..
You will need assistance from the Nokia care to format you phone and set it up with a true software.
So the next time do not download infected files but keep you phone clean to avoid such failures.
make sure your memory card is taken out and scanned , thebad files removed and reloaded with good files only.
Hi, First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your for memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card.and format with PC, 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone. Read and learn more about flashing and how to flash a phone on this link.
First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your fon memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card. 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy,
or
FORMATTING PHONE
Hello, Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
1:i think your mobile is infected with virus install kespersky anti-virus make sure that you have internet connection on the mobile select trial option and then update the antivirus and do a Full Scan if and virus is found remove it .
2:format your phone first remove your Memory card and backup all your contacts .type this code *#7370#, accept reset and phone restart,enter lock code (12345-default),and phone restars from initial country setup...
but do back up your data,before formatting...as everything will lost.
your phone might had ben infected by virus... try to scan your memory card in your pc, if there will virus found you must format your phone and memory card... backup firstyour files... hope to help..
Just rename the image as image name.jpg or cut paste it to ur pc then save i to the fone with the for mat jpg or gif....It will open....If not just format your memory card
