Question about Acer Aspire 7110-2069 Notebook
Help with my orbicam
I need helpgetting my acer orbicam to let me talk with others on the net
  • Anonymous Apr 20, 2009
    i don't have software for the built-in camera
Double Clicking on Acer OrbiCam OrbiCam window
ur cam may also used by hackers but possibility of this is very less. open task manager check process if there it is using by any then end that process. if problem not solved reinstall ur cam driver.
Jan 09, 2010 | Acer Aspire 5602WLMI Notebook
I uninstalled my acer orbicam and need to reinstall program help
If you uninstalled via device manager:-
Unplug Orbicam
Right Click My Computer >> Properties >> Hardware >> Device Manager
Plug in Orbicam
Click the top one in the list (Your Computer name)
Click Scan for hardware changes (small icon at top of device manager next to help button
Windows redetects any new hardware , hopefully it should find the camera , thenn you are prompted for device drivers :- Select automatically and see if it finds it
If not , download the drivers you mentioned above , then specify where the drivers are in the hardware wizard and it should reinstall everything then orbicam should work again
Dec 29, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Orbitcam does not work.
Been there. You need the driver in the Acer Site. Note !! you need the Acer Orbicam WHQL Driver as well as the Acer Orbicam Utility. The Orbicam webcam is a USB device. Pls follow this steps in sequence.
1. Install ChipSet/Lan Support.
2. Install Acer Orbicam WHQL Driver
3. Install Acer Orbicam Utility.
Nov 02, 2008 | Acer Aspire 9300 Notebook
Acer laptop 9300.my orbicam will not work with the windows vista premium can you help thanks ED.
Move all pictures in "My Pictures" folder to any other floder and reboot. The Orbicam should work
Sep 06, 2008 | Acer Aspire 9300 Notebook
Acer orbicam. help!
Ive been reading a discussion here:
http://www.theacerguy.com/2007/05/29/acer-orbicam-fix/
Im not sure how much progress was made in that entry on the site but it is worth trying,
Aug 17, 2008 | Acer Aspire 5050-3242 Notebook
How install acer orbicam in my lapTOP
Ask him if you are both using acer orbicam? If Yes, try to download latest software and uninstall your first your old software then install new software.
Jun 08, 2008 | Acer Aspire 5100 3010 Notebook
Acer OrbiCam not working (acer aspiral9412zwsmi)
Has it worked in the past, on this computer?
Have you recently upgraded to Vista?
Here is a suggestion:
There are two software entities involved – the camera Drivers and the OrbiCam application itself
The new driver and a new version of webcam application (below)
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
You need to download and install them both.
Mar 27, 2008 | Acer Aspire 5100 Notebook
Aspire 3684 orbicam not working
Please check in device manager, is it there ?
it's supposed to be under imaging device.
If it isnot there, it's mean it's hardware, it can be orbicam cable or orbicam itself is bad.
In this case, try to reseat the orbicam cable, it's beside power button, you need to open the power cover (power cover is long cover where the power button reside), you just need to remove 2 scews on power cover, it's in lcd hinges. there are 2 cable beside power button, the camera cable is the cable that come from lcd, not from uppercase.
if your orbicam is in the device manager, try to re-install orbicam software. if you don't have orbicam software, you can download it from www.acerpanam.com.
I hope this will help you.
Mar 21, 2008 | Acer Aspire 3680 Laptop
Acer orbicam
download the software from www.acerpanam.com.
you need 2 things.
1. orbicam driver (if you can see your orbicam in device manager, you don't need to install driver again).
2. orbicam application, there are 3 kind of orbicam (suyin, bison and logitech), I don't know what is yours. you need to try 1 by 1.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 7110-2069 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
