Intel D945 GTP is a motherboard designed by Intel however there are other manufacturers like Gigabyte, MSI etc that also has the same design such as that of Intel D945 GTP which more or less is compatible. As far as buying a new motherboard is concerned I would suggest you should look at the make/model of the processer that you are using currently and also check the type of ram that you have like DDR or DDR2 etc and check for motherboards that can work with what you already have along with better on-board graphics than Intel D945 in case if you are into playing games.
SOURCE: Intel D945GTP Motherboard
1)reset your bios with the help of the bios resetting jumper located around front pannel connecter,
2)Reset the mother board battery
3) Open the memory and switch it up. if you do not get a long beep sound this is possiblly a mother board problem
try this link.. http://www.userdrivers.com/Motherboard/Intel-D101GGC-Desktop-Board/download/
SOURCE: Intel D945GTP Layout
No problem M8!
Here you go!
http://www.intel.com/support/motherboards/desktop/d945gtp/tp_manual.htm
Good luck to you!
If you find my answer helpfull, dont forget to vote!
SOURCE: I want the Product manual for the D945GTP
http://www.intel.com/support/motherboards/desktop/sb/CS-020725.htm
