Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
ERR: SYNTAX i pushed the Y= button and entered my function to be graphed. Then I push the graph button and it says ERR: SYNTAX HELP!!
  • Adam McFarlin Oct 01, 2008
    When I push the y= button on my calculator I get a ERR: SYNTAX message, any idea how to get around this?
    thanks!
    -Adam
  • 30 Answers
Ok i had the same problem- If i remember correctly my "window" was messed up. Check it out... If not i always pull the "take batteries out while on" trick which resets the ram.
Posted on Oct 21, 2008
Err syntax pops up when trying to graph
You have a syntax error in the function you're trying to graph. Could you post the function in question?
Jan 17, 2013 | Texas Instruments TI-84 Plus Calculator
Syntax error for graphs
That hardly seems possible. Try graphing the function y=x.
There are a few ways to draw curves on this calculator
  1. Drawing functions
  • Type is y=f(X), the [X,theta, T] key enters X when pressed
  • Type POLAR r=f(theta), key [X,theta, T] enters theta w. pressed.
  • Type PARAMETRIC, requires an X=f(T) and Y=g(T) functions
  • Inequality graphing. You can also draw some functional inequalities such as y> 2X^2-3
  • Dynamic graphing (graphs where some parameter may be changing)
Drawing Relations
There are some other relation you can draw X=, X>, X< , and the drawing of general conics.
I hope that the foregoing remarks help you sort out the problem you are having. If they fail to do that, I suggest that you read the manual that shipped with your Prizm.
Sep 27, 2012 | Casio Prizm FX-CG10 Color Graphing...
I think I pushed a button [2ND][+], and [ClrAllLIsts]. After that, I tried to draw graphs, but when I push the [GRAPH] button or [ZOOM][5]/[6], it doesn't make any graph! What should I do...??
You do not say that you opened the Y= editor and typed in at least one function and THEN pressed Graph. If you do not enter a function, all you will get are the axes (if the calculator is configured to display the axes.
1. Open the Y= editor.
2. Type in a function EXample y=2X+1 (To type X press the [X,T, Theta, n] key)
3. Press ENTER to validate the function.
4. Press the GRAPH button.
5. If you do not see a straigt line press the ZOOM button
6. Select ZoomSTD
Sep 04, 2011 | Texas Instruments TI-84 Plus Calculator
My TI 84 plus silver: whenever I push the graph button the message ERR: Syntax 1:quit 2: goto appear on screen please help
Press the Y= button.
There are several possibilities:
1) Scroll through all equations, Y1 through Y9 and Y0. Make sure they are cleared.
2) The equation you typed in is not entered correctly.
3) Make sure Plot 1, Plot 2, and Plot 3 are NOT highlighted.
Feb 01, 2011 | Texas Instruments TI-84 Plus Calculator
How do I set it to factory default settings? When I want to graph or want to do a zoom fit I get a ERR:SYNTAX 1:quit
Seems unlikely that you get a syntax error for both graphing and Zooming. Probably the error is in the function you are trying to graph.
To reset the RAM,
Press [2nd]MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared.
Press [CLEAR] button to erase the above message.
Once Ram is cleared, open the [Y=] function editor and at the Y1= line, enter [X,T, theta, n] key or [ALPHA][X], to draw the simple function Y1=X.
If that works, that means your calculator is OK.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
Graph and trace buttons don't work
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
Entering inequalities into TI-84 to graph
I think you should get a Texas Instruments calculator and push the 'y=' button then put the equation like '2x+4' in the y1 area. You can put the X by using the variable botton. I hope my english makes sense I am not a native speaker.
Jan 19, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
957 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
