The temp is controlled by electronics that monitor the oven sensor.
The sensor should ohm out at 1100 ohms.
If it is shirted to frame or open the open temp would not do right and the
oven control would not know what the temp was and would probably declare an F-3 error.
In your case I don't think that is the problem. What i think it is going to be is the ignitor. If it is getting weak it sometimes won't draw enough amps to open the safety bimetal inside the gas valve.
Probably the ignitor is on it's way out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
