Computer won't boot, until I push the reset, then it goes through the post test then boot.
    Brigadier General:
  • 5,158 Answers
Expand on the information abit... does it finish booting to an operating system after you hit reset.... did it freeze while you were using the o/s and then you had to hit reset ?
brand and model of computer would help as well
Robert
Posted on Sep 01, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
Computer won,t boot up just beeps
Continuse beeping POST code usually RAM or video problems.
The problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Mar 30, 2012 | HP Pavilion m7470n (ER883AA) PC Desktop
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
My Computer will turn on and go to the windows XP loading screen with the blue bars and will won't load up, it rarely does but when it gets to the log on user screen it freezes
Right after your POST screen goes off,before you get to Windows starting,try pushing the F8 key several times until you get the Windows boot options.Then try 'last known good configuration".
If that doesn't work,you can boot from the Windows installation disk and try to repair your Windows installation.Let me know what happens.
And good or bad, please rate my post?
Bob
Aug 11, 2010 | Dell Microsoft Windows XP Home Edition
Pc will not post all lights including disk activity lights are on
The best way to test which component is causing the issue is to strip down you mobo to just the CPU. Then try and boot. If it boots, you know the CPU is okay. Start adding components until you reach the point where it won't boot. The last item added will be the item that is not functioning. If it won't boot with just the CPU, and all of your jumpers are correct, then your mobo is your problem.
Jul 20, 2009 | Gigabyte GA-8SG800 Motherboard
Computer can't find mouse...
Well your problem sounds like a unique one, however, I can tell you exactly when you're computer looks at your mouse. When you push the power button the computer goes into the POST mode (Power-On-Self-Test). This is a good minute before you see the Windows login. During POST the processor is detected, how much memory, what hardware is recognized and whether BIOS has Plug n Play. After POST the boot process starts, during the boot process there is a file called NTDETECT.COM, it is used to detect any hardware that is installed and adds that information into the Registry..there are some other files but it does not pertain to your problem. After boot is when you hear the beep on your computer, the one beep is saying all is well and ready for the operating system. So it sounds like your mouse is not being detected either during POST or when NTDETECT.COM runs during POST. Here are some steps you can take: First you must replace the mouse to test its electronics. If the replacement mouse works, the original mouse was defective. If the replacement mouse does not work then the original mouse's electronics are good. In this case the mouse driver or the port hardware is the problem. Find mouse in Device manager, uninstall driver, then reboot see if the Plug and Play picks it up. Update and re-install drivers. If the drivers don't work then its the motherboard, go back to the PS/2 mouse. Hope this helps. Let me know how it goes.
Jan 04, 2009 | Logitech Cordless TrackMan Wheel...
M2N-SLI Motherboard issue.
Hi
If your computer was ok before you changed parameters in Bios then it is Bios fault:
Re inter Bios and Try to reset it to default.
If you can not get into Bios anymore  the problem is serious:
You must reflash Bios or reset Cmos ,and it could be vga or may be the wifi if you have one onboard.
see if you have a hardware store nearby and let someone fix it
if you .
It seems to be a common problem on all Asus Motherboards:
bios,vga,post etc...
Dec 12, 2008 | ASUS AI Lifestylestyle M2N-SLI Deluxe...
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computers & Internet Logo
David Payne
David Payne
