Question about Denon AVR-681 Receiver
Receiver Problems I've had this receiver for approximately six years and have never had a problem with it. Recently when I tried to turn on the system it simply won't turn on. I know it's receiving electricity because the red standby light is turning on. Other than this light turning on, there is nothing else happening. Thank you
  • bdrescher Sep 01, 2008
    Thank you for responding so quickly. I didn't expect to have an answer until after the holiday.
    Great job
    Genius:
  • Denon Master
  • 1,689 Answers
The main power supply may have failed, and or the output stage may have failed. If the output stage failed, there will most likey be damaged parts in the driver stages.
Most likely the fuse is okay because the standby light is coming on.
This is not something you can fix at home. You can take the set to a service center that is familiar with the make and model of your reciever, or call the manufacture to find their authorised service rep, and have them make an estimate for you.
Jerry G.
Posted on Sep 01, 2008
I have owned an NAD 705 Receiver for many years, and am just now having problems (probably over 20 years old). I'm getting a message on the screen of the receiver that says 'protection' .
if the receiver turns on and operates then eventually turns off due to protection mode its because a wire is shorting out the receiver.if it doesn't turn on or goes straight into protection mode then its probably time for repairs or a new receiver.
Jan 06, 2018 | NAD Audio Players & Recorders
HDMI Error/HDCP Error
Hi, Try replacing the HDMI cable. My Guess is that you have a bad cable connection or connector. If there is excessive heat on cable connectors this could be bad. Cooling fan or other heat source
Good luck.
Jan 13, 2014 | Yamaha RX-V2600 Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Hi. I am picking up a buzzing sound. I have had this receiver for years with no problems. Any clue?
Most likely a ground loop. Troubleshooting is difficult.
Completely disconnect devices one at a time starting with the satellite or cable box. Listen for when the hum disappears. If you have recently installed a source (cable box etc) start with that. Have you recently installed any light dimmers? Cheap dimmers can also cause ground loops.
If it is in the cable or sat box you should try to get the incoming line grounded at the demark.
Or try this:
http://media.photobucket.com/image/ground%20loop%20isolator%20cable%20tv/Dimdirol/IMG_2885.jpg
Nov 23, 2009 | B&K AVR-307 Receiver
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
STR-DE597 Display is not visible
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Aug 04, 2007 | Sony STR-DE597 Receiver
Satellite Receiver Malfunction
Go into the menu and check the signal strenth to see if its going up and down or if its a stead as a rock. I have seen this problem be the reciver as I was a satillite contractor for 5 years in the past and I have installed 1000's. I have also seen your poblem be a small brance in the distance cause the freezing, also a bad connector from the lnb on the dish to the multiswitch, or a bad connector on the back of the reciver or even a pinch in the wire but the most common thing I have found would be a loose connection on the back of the reciver with the fitting wasent screwed on all the way.. If the signal is rock steady, the reciver will need to be replaced as the recivers dont pay to be repaired. good Luck
Jul 31, 2006 | RCA DRD485RG DirecTV DTV Receiver
Denon AVR-681 Receiver Logo
216 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
