Question about Nintendo Wii Console
Wii remote keeps beeping and not working - Nintendo Wii Console
    Scholar:
  • 125 Answers
Try this! I found it on Nintendo.com under support:
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • Posted on Sep 02, 2008
    My wii console keeps switching itself off
    Check the Wii remote battery life. Dead batteries in Wii remotes can cause the Wii console to turn itself off. If this is the problem, remove the dead batteries and insert new ones. If they're rechargeable, recharge the batteries.
    If this is not the problem, your Wii console might not be working properly. Visit support.nintendo.com or call 1-800-255-3700 for more information.
    May 02, 2010 | Nintendo Wii Console
    My wii remote keeps flashin but wont trun on
    You have to sync the Wii remote to the console.
    To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
    If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
    Feb 21, 2010 | Nintendo Wii Remote Controller
    Wii remote wont work change batteries and all lights at bottom just keep blinking
    Sync it.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.If this not help press and hold the red SYNC button on console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync Wii Remote again.
    Nov 04, 2009 | Nintendo Wii Console
    I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
    Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
    1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
    2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
    3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
    4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
    5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
    6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
    Re-sync the Wii remote to the Wii system:
    1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
    2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
    3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
    4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
    5. Repeat the re-syncing process with all other Wii remotes on this system.
    Thank You
    Oct 19, 2009 | Nintendo Wii Console
    What would cause the wii remotes not to hold a sync? what could be done to keep the sync?
    In order to not hold the sync you must not press the sync button more than once while the lights are flashing. In order to keep the sync you must play the wii at least once a day.
    P.S. Hope it works for the person whoever is going to use it.
    Apr 02, 2009 | Nintendo Wii Console
    Controller problem
    This normally happens when the battery,s in your Wii remote are low. Try a new (fresh) set of battery's. The alkaline type works best!!
    Dec 28, 2008 | Nintendo Wii Console
    Wii system stuck on the first screen and the hand is not come up
    Are the Wii Remotes Batteries dead? This can be a common problem as well as Wii Remotes becoming unsynced to the Wii. To resync the Wii remote:
    1. Open The Small Door on the front of the Wii and Take the Battery Cover off of the Wii Remote.
    2. Press the small red "Sync" button on the Wii and then Press the Small Red Button on the Wii Remote.
    You should he a "beep" through your TV speakers that confirm your Wii Remote have been reconnected.
    I hope this Helps. Take Care. =)
    Dec 08, 2008 | Nintendo Wii Console
    Wii remote
    open the wii remote battery cover
    press the little red sync button once, at the same time as pressing the little sync button under the sd card flap(on the wii) once.
    just one tap each and it shud work.
    dont keep the buttons pressed or it wont work.
    also some people sed to me you can keep '1' pressed
    Jun 13, 2008 | Nintendo Wii Console
    Wii remotes not working
    Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
    May 10, 2008 | Nintendo Wii Console
    Wii remote
    resync, red button under the front door and under the remote battery cover.
    Feb 05, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    1,173 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
