Regulator ic of sony tv kv-g21c1
What is the regulator ic of sony tv kv-g21c1?
    Genius:
  • Televison & ... Master
  • 1,689 Answers
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
Posted on Sep 01, 2008
Where do I find the 8 pin IC number
Hello
"D" power board is nothing, but its power regulator board itself. I think you are not handy to do the work with power regulator baords. It is dangerous to handle power boards to any TV without proper experience.
Mar 01, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony trinitron, about 7 years old, turn it on and picture won't come on for about an hour
Check for bad connections on voltage regulator ic, or bad voltage reg ic in power supply.
Oct 23, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega kv-34hs420 worked fine last night never had a problem with it before. Today i went to turn it on and i get no picture and the stand by light is blinking 6 times every cycle
your tv has problem in the horizontal circuit caps in the horizontal circuit should be checked also the jungle ic.and the regulator in the power supply.have a tech repair your tv if your are not a tech. good luck.
Aug 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have the same Problem with my sony KV-32HS510
Your set needs two regulator ICs replaced and a capacitor . I recommend taking it to a sony authorized servicer.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My Sony Trinitron KV-AR34M86 is showing 5 blinks every 2-3 seconds interval while powered on. Display is also pinkish. Please help. I can work down to component level provided instruction is given. Thanks...
Hi
please try to check the board at the Jungle Chroma section, check the supply voltages tru Jungle IC then check the Regulator of Jungle power supply if this is 5, 8. or 12Volts. please check. if the requirements is same by the given regulator viltages.
Thanks!
Jun 11, 2009 | Sony KV-AR34M66 34" TV
Sony Vega Service Codes
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Jul 15, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
SONY KV-27v36
this problem would be in your power spply or the sweep derived power supply. probably a bad capacitor or regulator IC/transistor. Unless you know how to trouble shoot electronics them please have this set looked at by a pro. Good Luck
May 25, 2006 | Sony KV-27V36 27" TV
Televison & Video Logo
270 people viewed this question
Top Televison & Video Experts
