Question about Dell Dimension 2300 PC Desktop
Adding second hard internal hard drive
The original IDE cable only supports one hard drive for this computer. Will a new cable that has a second connector for a slave drive work in this computer. Can you tell me if the BIOS will accept the second drive. I would like to install a Seagate Barracuda 7200.10 160Gb ata/ide drive.
    Genius:
  • 1,847 Answers
Sure it will, put the jumper setting on the hdd to cable select mode.
Posted on Sep 01, 2008
New 1tb hard drive not recognized in bios
it is like putting a new stereo in a totalled car,
May 29, 2015 | Hitachi Computers & Internet
How connect slave drive dell computer?
I assume you are trying to add a slave drive to a Dell DESKTOP? If so, is it an IDE drive (standard hard drive). To that you will find a jumper plug, usually beside where the cable plugs in but sometimes on the opposite side. The jumper options are usually listed on the drive but what you will need to do is place the jumper plug in the slave slot. You will also need to move the jumper plug on the original hard drive to the master slot. That always seems to work the best for me. However, you can try adding plugging the slave drive into the next open slot on the IDE cable, which is already plugged into the original hard drive. If you get lucky it may automatically recognize the new drive as the slave. You may need to setup/configure the BIOS to set the master and slave drives. To check BIOS setting, hold F2 or F10 when you turn on/boot the PC.
Apr 20, 2012 | Dell Computers & Internet
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Apr 11, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
I want to install a seond hard drive in computer
can you please open up the CPU and check one thing? Is there any Free port in this cable? One end will be connected to the motherboard and two others to (1)CD/DVD rom and (2) Hard drive.
If there is free, surely you can add one. Please then look for a place where you can place your (ATA not the sata one) harddrive.
Apr 05, 2009 | Dell Dimension 4300S (Refurbished)...
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Won't reconize DVD burner
Well, the CD ribon cable goes into the IDE 2 slot on the Mainboard and the furthest connector on the other end is the master, the second one closest to the board is the Slave connector. The CD drive has a jumper on the back between where the ribbon and the power connector go, on the case some where it should have a diagram showing the jumper setting to put it in as master or slave. Set it accordingly.
Same with Hard drives.
If the Hard drive has a diferent Cable like a SATA, then be sure to get a SATA as the new one.
Now the IDE cables may be bad check them for damage just to be on the safe side.
Feb 04, 2009 | HP Compaq dc7100 PC Desktop
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 2300 PC Desktop Logo
369 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
