Question about HP Jornada 680 Pocket PC
Jornada 680 won't sync over network
Hi, Just got my Avaya WorldCard Silver 802.11b card to work with a Jornada 680 but can't get it to do a sync with my PC over the network. I'd established a partnership with the PC via serial and both "Network Connection" and the PC computername come up in the ActiveSync options on the Jornada. But when I attempt a Connect, the "Connecting to Desktop" window comes up with "PC contacted. Locating connection agent. Please wait...", then shortly disappears without making a connection and no activity on the PC. I've tried this with both ActiveSync and Outlook open on the PC with no effect. I know the Jornada and PC are talking OK over the network because I can ping the Jornada from the PC, and can browse shared directories on the PC from the Jornada using Pocket IE. Only other relevant thing I can think of with regards to the PC is that it's running XP & ActiveSync 3.6. Any ideas?
    Master:
  • 450 Answers
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Posted on Sep 12, 2005
SOURCE:
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
Need help with Jornada 680 Memory Upgrade Installation
http://home.freeuk.com/gogmagog/installation_guides/6xx/installation_guide_memory_680_680e_690_690e.html
Sep 12, 2005 | HP Jornada 680 Pocket PC
Jornada 820 and Wireless
It is possible, but you need a notebook PC Cards (PCMCIA) that supports Windows CE 2.11. Most Compact Flash wireless LAN cards need Windows CE 3.0.
Sep 12, 2005 | HP Jornada 820
Jornada 680 "booting cold"
Sounds like a loose connector inside, I had a similar problem after I took my 680 apart to replace a cracked screen. It took a few more dismantlings and re-assemblings until it settled down. You should also check the state of the button cell battery.
Deleted Items Sync
did u empty ur deleted items folder in outlook if u did to stop it from syncing the e-mails open up active sync and go to tools options and then uncheck the e-mail
Sep 12, 2005 | HP Jornada 565 Pocket PC
Jornada 820 - WiFi cards HELP
Can you try inserting the card and resetting the unit with the reset button. When the unit is back up got to start>programs>communications>remote networking then make a new connection. Choose dial up connection and select your card.
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Jornada 680 and email
To get to pocket MSN and Hotmail... http://mobile.msn.com/pocketpc/
Jornada 680 cannot get out of calibration
Whats the operative version that you have? Maybe be a hardware issue but better first try to update what you can. Please update.
HP Jornada 680 Pocket PC Logo
140 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
