2000 Mitsubishi Eclipse Logo
Posted on Jul 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a Diagram on the Serpentine belt for an 2002 Eclipse. I need to know how to bypass the AC compressor.
joseph cayo
Level 2:
Scholar:
  • Expert 192 Answers
  • Posted on Jul 30, 2011
joseph cayo
Expert
Level 2:
Scholar:
Answers
192
Questions
0
Helped
56801
Points
489
The compressor cannot be by-passed, but you can disconnect the compressor clutch by disconnecting the two wire connector at the compressor; then the compressor pulley is just an idler.
  • Anonymous Dec 01, 2011
    the compresser right now is locked up tight if i disconnect the wires it will unlock it up so it is an idler?
danoyachtcap
Level 3:
Top Expert:
  • Mitsubishi Master 2,907 Answers
danoyachtcap
Mitsubishi Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275640
Points
52081
I need a Diagram on - 0996b43f80208338.jpgWhich engine do you have??
1helpful
2answers
I have a 2002 Oldsmobile Alero what do I do to change the bypass pulley do I replace the ac compressor
You evacuate the AC system. You remove the serpentine belt. Then you remove the compressor. But the hoses and secure the cut ends so they don't rattle around. The bypass pulley will fit in place of the compressor. Then you install the serpentine belt
I need a picture of serpentine belt diagram bypass AC compressor
purchase shorter serp belt .. for without air con
and remover the compressor
3answers
Can I use a short serpentine belt. AC compressor isn't working.
I have a 2000 E430. I just did this job because my ac compressor froze. I went to O'reilly and bought a serpentine belt 6pk2310.(different brand has it as k0910). The numbers after the part number is the length in mm or inches. Eg. 0910 = 91 inches == 2810mm. Just follow the diagram and bypass the ac compressor. Tools: 15mm wrench for the pulley tensioner. It took me 5 minutes to do this job and be on the road again. It is very easy.
On the Right is the normal diagram.
On the left is how you bypass the AC compressor on a E320/E430 2000-2002 engine.
I need a diagram to put a serpentine belt on it bypassing the air conditioner compressor
Ford 150 250 How to Replace Serpentine Belt
scroll down to section 3 and it's the 3rd pic
good luck bypassing that AC pulley, from the diagram i dunno if you can with the way the tensioner is going to pull on the belt
2008 mitsubishi eclipse 2.4 sepentine belt routing need to find a way to by bypass the AC
You got to buy a shorter belt serpentine belt that bypasses the AC unit most car have a diagram showing whit and whit out AC.
2helpful
New routing diagram for the drive belt on my 2004 Cherokee. new belt is 13 inchs shorter (this is to eliminate the squeek problem), my local garage is reluctant to advise me!
Click on the following Link. It has the two (2) Serpentine Belt Diagrams.
I believe the Mechanic is bypassing your AC Compressor.
When you look at both of the Belt Routes you can bypass the AC with the shorter belt.
In the first Diagram: the Belt would go from the Power Steering Pump, bypassing the AC and going directly to (over the top) of the Water Pump.
In the second Diagram: the Belt would go from the Tensioner, bypassing the AC and going directly to (under the bottom) of the Water Pump.
Let me know if this helped, or if you have additional questions or information. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2004/make/jeep/model/grand_cherokee/2004_jeep_grand_cherokee_drive_belt_routing_diagram.htm
Changing the serpentine belt with out an air
I had to do that once, but it was on an older vehicle that AC was optional. Probably your best bet would be to see if you can wrap the belt on there, but bypass the AC pump. Then just mark the belt with a white marker to get the length you need. Take it to the parts store and have them measure it with their guide. They should be able to find you one that length. If a Rendezvous came without AC, you could just go in and ask for the belt for one without AC, but I don't think they did.
4helpful
2answers
My AC compressor went out on my 2004 Chevy Blazer. Since winter is here, I just want to bypass the ac. I bought a belt for the same yr/make without ac. Where can I find a serpentine belt routing diagram to...
its the same. but a different pulley takes place of the a/c compressor. I know DORMAN makes a few "bypass pulleys" to do this, but dont know if they make one for your truck. at the worst... you will need to get a pulley and bracket from the dealer for a truck without a/c . as long as your a/c pulley bearing is ok, you can let the belt run there.
Air con disconected
If the air compressor is bad... check the diagram under the hood for the serpentine belt. Most vehicles will have a diagram that displays the serpentine belt path along with a part number for a shorter belt to bypass the ac compressor. If you can't find the diagram, go to your local parts store and they should be able to help.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
