Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water line leading from primary pump
How do you disconnect the water line leaading out of the primary or first pump? I pulled back the inset ring around the water line but the waterline won't come free.
  • 120 Answers
Use a pair of needle nose plyers to push back the ring and just pull it has to come off but if you are repl the valve then just use a sharp nife and make a smooth cut and cut it off
Posted on Oct 15, 2008
No water comming through my ge profile artica
Sometimes the water line freezes in the door. You may have to open the door for a time. If you can find where the water line goes in the door. there is a connector where you can disconnect the water line. this is a push connector. Push in the ring around the tube and pull the tube out. Press the water dispenser for a second. if water comes out the tube if frozen in the door. If not it could be the water valve. Push the tube back into the connector.
Oct 09, 2014 | Refrigerators
How do I disconnect the waterline in the back of the frig
there is a small nut over top of the line, some models it's hidden behind a cover. Make sure the water is shut off, then undo the nut and pull the line out. It may stick a bit as there is a seal under the nut.
Jun 15, 2014 | Kenmore Refrigerators
How to connect water line to water inlet valve
The brass ring cannot be reused. You cannot buy it separately but it is inside any 1/4" fittings available in your local adware store.
be sure to cut the end of the waterline and install the ring on a Fresh section. Also, make sure the waterline is lined up with the valve inlet before trying to tighten up.
May 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Monogram sxs leak
you need to access the back of the fridge and disconnect the waterlines going to the filter base(on the water valve or the main line coming in for example). After you disconnect the waterlines going to the filter base you can pull the base out, and replace the base. Hook the waterlines back up to the same spots you disconnected them from, and you should be good to go.
Aug 03, 2013 | Refrigerators
Need to remove doors from a Shelvador side-by-side fridge to get into house.. How to disconnect water line to door?
Most of the water lines have a quick connect fitting down at the bottom under the unit. Open doors, remove kick plate and follow line back. Should have a connection in that area.
Aug 18, 2012 | Refrigerators
Disconnecting the waterline
Hi, If you remove the grille below the doors, you can see a plastic water line passing through the lower hinge. Follow the line back about 6 inches and there should be a quick disconnect. It may be a screw type or the kind that you push down a small ring to get it to release
Apr 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking out of fountain
You have a bad water valve. Order a new valve using your model number, pull the refrigerator out, turn off the water and find the valve by following the house water line to where it attaches on the refrigerator. This is your valve. You usually have to remove the backing plate to get to the valve. Remove the valve mounting screws, disconnect the waterlines and reattach to the new valve one at a time. Same with the two sets of wires, one at a time. Reinstall and test. Fairly straightforward. Good Luck, Appliance Specialists
Dec 10, 2009 | Whirlpool Refrigerators
How to remove fuel pump
Disconnect battery, remove gas cap, disconnect wiring harness and fuel lines, disconnect filler tube bolts.
Secure jack under tank, remove support straps and tank bolts and lower tank.
Using nothing but a BRASS punch and hammer, knock the ring counter-clockwise on tank, Loosen and remove ring around center top of tank, pull out sending unit and fuel pump.
Aug 01, 2009 | 1998 Chevrolet Astro
Water dispenser...
I had the same problem, in reading a bunch of other similiar issues with various models, the best thing I found was that the water line inside the freezer door is frozen. I had to isolate this portion of my water line from the wall all the way through the frigde. It you unplug, take out screws from he back cardboard cover so you can follow the waterline through the fridge. The valves are pretty easy to take apart/put together. To take apart a valve, just press down on the ring around the valve the pull the connecting apart. To put back together, push the same ring down, then push the connection back together. To check the water flow, plug the fridge back in and have some one push the water dispenser as you check each valve. I suspect the problem is in the freezer door, so you should just check the valve under the bottom left side of the freezer door. From here to the dispenser the water line goes through the door. I used a blow dryer to heat up the inside of the freezer door just behind and below the dispenser unit for about 5 minutes. Try and run the water again and it should work. Good luck
Oct 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We had to take of the doors on a whirlpool sie by side refrigerator. On the side with the water line going into the door, we had to pull of the grill on the bottom and disconnect the water line. Now when...
yes easy this is called a "john guest" fitting probably after the now fabulously wealthy man who invented it. push the ring in BEFORE you remove the tube and you can use them again. availabe @ hardware and appliance supply stores everywhere
good luck!
Apr 25, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
