Question about HP Jornada 720 Pocket PC
Loose Hinge
In the last few weeks the hinge on my 2+ yr old 720 has become much looser than before. Is there any way to tighten this myself?
    Master:
  • 450 Answers
Well, if you really want to know where the screws are, they are under the "Hewlett Packard" and "720" labels on hinge of the display. However, there seems to be some "screws and glue" fix available from HP to solve loose hinge issues. I'm not very sure abt this (could be for the 728)
Posted on Sep 12, 2005
How to tighten binocular hinge
Simple solution: Pry or unscrew the cap covering the end of hinge shaft on the rear of the binocs (between the eyepieces). Use a screwdriver that fits snugly in the slot on the end of the shaft & tighten to desired tension. Place a dab of Goop-type cement on the inside of the cap if it was pried off & press it firmly back on the shaft . Helpful hint: Slide a small knife blade (an old dull one you don't use for cutting) under the cap and gently work your way around to pry it off. Note the position of the index numbers before you remove it so you can replace it in the same position.
Feb 27, 2012 | Nikon Monarch ATB 7345 Binocular
How do you fix a soft closing toilet seat where one hinge has become loose, one side has become detatched
Sorry there is no fixing one. the reason the hinge probably came loose is the wood has cracked and/or the wood got wet and rotted and the screws won't stay tightened. Go to Walmart and get you a new seat.
Jan 29, 2011 | Home
We have a 10 yr old GE Advantium SCA2000. The door appears to be loose at the hinge. When closed the door slightly drops down just enough for the oven not to start or once running it will stop. How can...
Here's the full service manual with installation instructions.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You may also need to see this file on door switch checking.
Aug 21, 2010 | Microwave Ovens
Nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Feb 28, 2010 | Nikon Optics
Dell won't help the little people!
Give us a call at 800-595-3564 and we will help you get the part. Dell is a horrible company as we've had bad experiences with them.
Jan 18, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time......
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Jun 25, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Sony vaio vgn fw21l,loose hinge
My hinge broke on my Sony VAIO and the solution I found was to purchase the Service Manual for the laptop then take the laptop apart and find out which part number the hinge was. Then purchase the hinge directly from USA, which took 1 week to come through and mended the laptop myself.
Sony are doing this to everyone who has problems with the hinges of the laptops as they state the guarantee covers everything EXCEPT the hinges. If you can get proof from a pc repair shop that the hinges are a design flaw then Sony will repair it free of charge, but they will still request a Diagnostic fee which will be refunded if the problem you described turns out to be true.
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
HP Jornada 720 Pocket PC Logo
94 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
