Question about NEC Shielded Serial Cable (S1424-12S)
Connector Cable RS-232C of the Pocket PC
i'm brasilian user the Pocket PC A-10 or A-11, its the same. I need the connector cable RS-232C, to exchenge data whith others machines, and other cable whith AC adapter. The RS-232C cable has a 16-pin connector on one end for connection to the A-10/A-11, and a 9-pin connector on the other end for connection to the desktop computer and others.I know that Pocket PC very old, but i need buy this cables. You know where can i find,and if i can buy in Brazil? I'm very thanks for this information.
Roberto Naves -
  • 3587 Answers
SOURCE: Syncing my MobilePro 790 with my computer
yes...quite an issue, eh? what is the actual model and make of that device?
Posted on Mar 20, 2008
  • 1179 Answers
SOURCE: What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 23, 2009
  • 382 Answers
SOURCE: Don't know which pins to connect the power sw cable to.
Here is the Layout and installation of your board. Hope this helps.
Posted on Jan 29, 2009
  • 32281 Answers
SOURCE: i have NEC versa pro laptop intel celeron with 500
Laptops do not have IDE cables, the 21/2"hard drive is connected directly to the motherboard via a 44 pin socket.
What do you need an IDE cable for?
This cable would be difficult to connect into the laptop's motherboard hard drive connector.
Do you want to connect and test a laptop hard drives?
It is easier to use an USB hard drive adapter, all you need to do is connect the hard drive to the adapter and plug this adapter into a computer's USB port and the computer will detect it as an external drive (provided the hard drive is OK).
Posted on Feb 27, 2009
  • 252 Answers
SOURCE: i need a monitor cable pinout, what color wire goes to which pin
Posted on Sep 02, 2009
Topcon GPT 3205NW. Instrument won't stay on RS232c cable setting. Change setting in Topcon from F1: Bluetooth to F2: RS-232c (cable) and push ENTER it flips back to F1: Bluetooth. Any ideas ?
Thanks for choose the Fixya..
It can be helpful for you to set the correctly, and please check the connection of serial (RS232) may be they are short.
Please feel free touch us if your problem not solve.
Prashant Sharma
Apr 16, 2016 | Computers & Internet
LQ-300-2. Where can I get a connecting cable?
To connect to a PC, a network, what? According to Manual you can use a USB cable to your PC or a parallel cable. The Parallel cable plugs into to RS-232 connector on your PC if it has one. It looks like a Video connector plug but is about 1.5-2 inches long. You will need a RS-232 Cable to connect. It has a pin type connector on 1 end and a weird sort of connector on the other that looks like a plastic ridge with flat brass contacts on both sides. See Pics . First one is PC plug and second is Printer plug
Sep 02, 2015 | Epson Office Equipment & Supplies
How to see video from Apple QuickTake camera?
Oh my! Well, the QuickTake 150 has two connector ports, RS-422 serial (Mac), RS-232C serial (PC). You need a converter cable, which you can find on Amazon or other places. The files are difficult to read on a modern system, but QTK format can still be decoded using the open source program dcraw or the OS X application GraphicConverter.
Good luck, sounds like fun! :)
Feb 06, 2014 | Apple Quicktake 150 Digital Camera...
What lead do i need to down load to my pc
Hi - That camera is pretty old and was before the wide use of USB cables. It uses a proprietary serial (RS-232C) cable that would be hard to find (none on ebay - I checked) and if found might cost more than the camera is worth.
Regards, Mikeywaf
Feb 28, 2011 | Olympus Camedia C-830L Digital Camera
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
and it it at ebay just type the right name
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Replacement remote needed for Polaroid DVDR DRM-2001G
You need to change the IR LED in the remote. I swapped in a new one from an old remote and it works great, no pointing and walking up to the unit with the remote.
Apr 08, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
NEC Shielded Serial Cable (S1424-12S) Logo
74 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
