Question about Apple iPod MP3 Player
Volume limiter on ipod
Limiter on ipod set really low
    Problem Solver:
  • 8 Answers
Go to the main screen, scroll to settings, scroll to volume limit, scroll it all the way up. Then either hit the play button and enter a 4 digit code to save it, or hit menu to return to the previous screen and it should save on its own.
Posted on Dec 17, 2008
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
Music wont turn up -- too soft to hear properly
It could be that the maximum volume limit has been switched on too low.
Go to settings then playback and then volume limit, the volume control shows the maximum volume it has been set to. Use the click wheel to select your maximum volume and then press the centre button to set the limit. Then choose done. Hope this helps.
Very low volume on a brand new ipod touch what should i do to fix this problem
Turn on Ipod, on the left hand side there is a volume control switch. While you are on a song, hold the top of the volume control switch to increase the volume.
If that does not work then touch "settings", then touch "music" and make sure your "Volume Limit" is set to "Off", if it is not touch "Volume Limit" and set it to "Off".
Please do not forget to rate me
May 16, 2010 | Apple iPod touch Second Gen (8 GB,...
I have an apple ipod. but volume is very low how to solve it.
It sounds like the volume has been limited. Go to settings and then volume. Then set the volume to volume you want.
Nov 06, 2009 | Apple iPod classic MP3 Player
Volume stays low won't increase
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
Apr 06, 2009 | Apple iPod MA446LL/A MP3 Player
Why my ipod doesn't play but the picture comes up in the headunit, what setting do i got to have
check the settings on the ipod and depending on what kind of ipod it is , make sure the volume limit is not locked at a low volume.
Mar 16, 2009 | Alpine Car Audio & Video
Apple Ipod voice problem
hi
i had the same problem with my ipod and the volume limit control had been set to playback at low volume...if you have the ability to change settings try this ; when ipod switched on , go down to "settings" and click on this and then select "volume limit" ; click on this and then use the wheel to set the maximum volume you wish to use ( i set it at about 80/100 to ensure no distortion) hopefully this will solve your problem
Dec 25, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod MP3 Player Logo
49 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
