Question about Sony Cyber-Shot DSC-H1 Digital Camera
H1 - blurry/soft pictures
Hi there - I've had the H1 for about a month. Overall it seems to be a very good camera although I seem to be having inordinate amount of difficulty in learning how to get a really sharp crisp picture. Mostly capturing pictures of kids, family, etc. I've had much more luck lately in shutter priority mode w/ shutter speed at 1/200" in good light (indoors w/ good amounts of daylight coming in through open windows). After looking at the exif data, I'm concluding that the auto/standard modes seem to pick shutters speed that are too slow - eg 1/40" all too often. And even 1/60" seems to be too slow if there is any slight movement. I'm wondering if others have had similar learning curves on this camera? Its gotten to the point for a while I was wondering if something was wrong with the camera when even some of the 1/200" pics have been blurry. Is this par for the course? Thanks in advance for any advice/comments.
    Master:
  • 551 Answers
I'll bet you're in continuous focus mode instead of Monitor focus mode. In CF mode, the camera keeps focusing even -after- you half-click the shutter. In flash mode (which takes longer to fire than non-flash), going out of focus is really easy in Continuous mode. That was designed to track a moving athlete (and it ain't that good to begin with!). There are two possibilities: 1) You're in continuous focus mode. Change your setting on the Setup menu!! 2) You focused on your child but the chair in front appears to be in perfect focus. If you get the same result in Monitor mode with center-focus, return your camera. There must be something wrong with the calibration of AF! BTW, I almost never get a blurry pic with the H1. Hope this helps...
Posted on Sep 12, 2005
    Master:
  • 551 Answers
Definitely use centre/spot focussing. AF has a tendancy to lock-on to a static object if the main subject is moving as the posted picture shows, then the flash exposure is calculated tho it is very close to the edge of the frame - did you reframe the picture as you were taking the shot? or is this a crop?
    Master:
  • 551 Answers
Imho this is a case of focusing on the wrong subject. Try to use to focus on the eyes of a human subject, maybe switch to the center af or spot af (I use 70 percent center and 30 percent spot af, no wide auto af).
    Master:
  • 551 Answers
Question is if you have motionblur due to you moving the camera or blur caused by the suvbject moving (something that often happens with children etc.) The first should be taken care of by the IS system, make sure it is on. I took Hot Air balloon shots at 1/10th at dusk which are very sharp (handheld) In the second case were the subject is causing the blur either use flash, increase iso or use a faster shutterspeed (in P mode you can use program shift with the little wheel on front of the camera as well to change the shutter/aperture) There are physical limits that dictate what speeds to use to freeze a moving target. The numbers you named are just to low, that is why you get better results at 1/200th. Also remember the rule of thumb : use at least the same shutterspeed as the focal length your at : so at 60mm use at least 1/60th, at 200 use at least 1/200 and at 400 use at least 1/400. This is for non moving objects, moving objects need faster shutterspeeds. On the other hand the IS system will with some training enable you to use much lower values specially at the tele end. In the film days I used a 400 mm F2.8 prime lens on a very expensive Gitzo tripod and still had problems due to blur caused by the mirrorslap of my slr at lower shutterspeeds. Sousing handheld 432mm at 1/60 which is perfectly possible with the H1 (of a non moving subject) is simply amazing. My advise as always get a book on photography that explains the meaning of iso, shutter and aperture and their effects on picturetaking. This will make the matter much easier to understand and will lower your learningcurve. good luck (and don't give up)
    Master:
  • 551 Answers
Under normal conditions, you should not be getting blurry pictures from the H1 at 1/200th. I don't. I assume you're shooting hand-held. Is the Image Stabilization turned on? What zoom are you using (shake is dramatically increased at high zoom levels)? There is a difference between motion blur and camera shake.
    Master:
  • 551 Answers
I'm afraid this is more a learning curve in general photography :-) I know I also fell into that pit, after so many years of 35mm usage!, by believing at first that "digital" can do it all, well it can't fool general laws of photography/optics :-) .. once one has mastered that, things have a tendency to go a lot smoother :-)
My photos look blurry not focused. Have tried turning off the auto focus and manually focusing. They are always slightly out of focus, why?
check and make sure you do not have the soft focus turned on. that will make the pictures "soft" in focus or seem out of focus.
Feb 03, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
My pictures seem blurry and a bad quality. help
It may be as simple as a wrong selection in your menu, check that it's not on 'Macro' as this will not focus normal distance. good luck
Nov 24, 2009 | Nikon COOLPIX S230 Digital Camera
Finepix A350 - everything is blurry
I had the same problem. I tried a reset in the camera, also reformated the card through the camera once I had done a reset. At present it seems ok.
Aug 17, 2008 | Fuji FinePix A350 Digital Camera
Sony start up and shut down
Problem seems in Loading Motor of Lens Mechanism. Its quite complicated Lens Mechanism. If you dont know about Camera Lens repair, please contact nearest Sony Service Center for proper repair.
Aug 15, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Blurry pictures....
reset the camera and try taking pictures using by soft pressing the shutter instead of a hard press... on digital cameras, hard fast pressing will cause the picture quality to be not as good
Jul 31, 2008 | Olympus FE-230 Digital Camera
Digital camera
you can try and adjust the contrast for that pictures. try also iso 300 for the picture to increase quality. downpoint is its size will increase. just explore the settings and try them all out. im sure you will find the perfect settings that you'll like
hope this helps.
fixya!
Jan 31, 2008 | Cameras
Sony Cyber-shot Digicams - Picture Quality !?!?!?
I'm assuming you purchased a Sony as replacement. If that's the case, take it back and ask for a new one or have it checked out. Something sounds horribly wrong to me. If by chance you got one of those Chinese/Taiwanese cameras. Give it away and go back to the P72. Of course, a few hours reading the manual and playing with the camera may solve your problems. Don't try to get fancy first off. Stick with Auto modes until you get a feel for what you're doing. If you are using Auto the go back to the first sentence :-) BMW
Sep 08, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
