Question about Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone
Changed active line, which changed my Unlock Code
So i was fiddling around on my phone and i changed my current number to the other active line option 000-000-5283. well after curiously doing so my phone shut itself off and of course i turned it back on. by the way my phone is a Razr. any way it asked me for an unlock code. well my unlock code has always been 2277 but it didnt work and neither did 1234, 0000, 1111, or the last 4 numbers of my phone number. so as of now my phone is sitting in my room, asking for an unlock code that i dont have! please help me.
Get a new phone ,keep your hands off next time!!!
Posted on Sep 03, 2008
How do i rest my phone,when i locked for got my pascode and dnt remember my number? I have a LG Cosmos 3.
To unlock the password on your LG Cosmos, you need to re-program your phone. This will default the code to the last four digits of you cell phone number.
You First need to temporarily activate the ESN (also known as MEID, HEX) off the back of your phone underneath the battery to you Verizon Wireless cell account.
You can change the ESN (Electronic Serial number) as follows:
1.) Verizonwireless.com
2.) Dialing *228 opt. 1 from the phone you want to activate, while the current activated phone is off
3.) by calling customer service to temporarily activate the phone (1-800-922-0204 or *611 from a Verizon Wireless handset not involved.
(note: most all phones, even if their locked should still be able to call 911 and the programming number (*228)
You can activate the phone for a day to an existing account just to do this if necessary.
Once you change the ESN on to a phone number and program it
Dial *228 on your phone, listen in and pick option 1 for programming.
after listening to music for about a minute or two you should hear "programming completed successfully"
Once you hear this you can hang up the call. The phone should reboot by itself.
If not power it down manually and then power it right back up.
now you should be able to unlock the phone with the last four digits of you cell phone number you chose to activate it too.
Dec 16, 2014 | LG Cell Phones
Trying to unlock samsung sch-u350 that currently with verizon. help me plz
It should be the last 4 digits of the cell number, if it hasn't been changed. To reset that, dial *228 send, option one. The phone will be reprogrammed and the lock code will be the last 4 digits again. Please respond and vote if helpful.
Oct 16, 2009 | Samsung Smooth SCH-u350 Cell Phone
If I don't know the last four digits of the assigned phone # how do I get around the lock code? i have a cricket phone and i forgot my security code to it and i need to unlock it and it will not unlock i...
i had this happen also and i had my number changed then my cuzin locked my but my code changed to my new # try the last 4 numbers of the new number and try the hole number with out the area code..
Jan 13, 2009 | UTStarcom CDM7025 Cellular Phone
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Forgot my lock code
The default lock code for any Verizon Wireless phone is the last four digits of your phone number. If you've changed the lock code, then you have two options:
1. LG phones can be reprogrammed even when locked, so dial *228 and press Send. When you hear the woman's voice choose option 1. When the call ends the phone will reboot and your lock code will be changed back to the last four of your phone number.
2. Bring the phone into a Verizon Wireless store, where they can read the lock code off the phone using their computers.
In the case of the original poster - if your phone isn't activated at all, as in it is not currently active on any phone number, then go with the second option. You could, if you really wanted to, call Customer Service and have them put that phone onto your phone number, then when you activate it (*228, send, option 1) the lock code will be the last four of your phone number.
Sep 26, 2008 | LG VOYAGER VX10000 Cellular Phone
Forget the phone lock code
if the code hasent been changed from origional it will be the last four digits of the phone number
May 27, 2008 | Samsung SGH-U600
Unlock code for sony ericsson Z200
By default the unlock code is the last 4 digits of the phone number(or last phone number assigned to it if it is not active), unless someone changed it to something else, in which case there is nothing you can do.
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Lands Phones
Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
