Question about EliteGroup PT800CE-A Motherboard
Please help me!
I have a desktop computer and my problem is when i turn on my pc its not booting and no beep, and no display at all and the red led is just on. I tried to used another ram that i thought it was a problem but i just wasted my money then i also tried to replace another agp card and there's no way to solve it. I also tried to clean all pc's but i can't solve the problem.. Hope somebody could help me of this..
  • Anonymous Sep 27, 2008
    My desktop is using a PT800CE motherboard. It's only 3 yrs old. Use it for games. Recently it was working smoothly then all of a sudden it turn-off. I replace the ATI video card with another that had higher memory (256mB)thinking that it was busted, still nothing happened, no display, no sound/beep nothing. Even replaced my 512 RAM with 1Gb. Still no good. What could be the matter?
  • enigma pulp Dec 27, 2008
    but it doesnt get to boot up when you start turn on the pc..?what could be the problem?tnx!
  • 797 Answers
Hi:
These two may not be the same problem.
As another has said, the first one could be CMOS problem. Get to the cmos by hitting del. on most machines, some use other keys, make sure you watch it closely as it turns on, and hit the key.
See what the settings are. If the settings are ok, then go on to test, if not suspect the battery. Replace it and set the bios/cmos to the settings preferred.
Second one....
You said it turned off. Suspect the following:
Power supply, CPU or fan or both, possible other causes such as hard drive.
Usually the ram would not cause a problem like this...you would at least have some power at the mother board or fans.
You can try this.
The power switch can be a problem here. Test the power switch to see if it is good. One way to do that is to disconnect it from the mother board or remove it from the case, and use an ohm meter to test it(with the power off of course). Some power switches are hooked directly to the power supply. You can remove the power switch from the case, then short the two wires to try to start the system, if that does not work, then it probably is not the switch.
Remove all pc cards from the mother board. unplug any fans, and the hard drive/s, except the cpu fan...we need that.
Only the power supply should be connected, then try, if nothing, continue to test.
See if the computer will turn on. If it turns on, then you need to test each item one by one to see where the computer will not start. The reason I say this, is that all the later power supplies will detect when a short or problem with a component happens. The power supply built in protection will not allow the system to start at all. However, you may hear a very small click or the fans may move a little bit, that is only if there is a problem somewhere in the system when all is hooked up.
Try another power supply, if you can get another one, pref. to borrow or use one you have around.
Examine all cables going to the mother board. Check that they are plugged in correctly, especially the power cables.
One thing here that can stop a computer is a bad CPU, or connections which are not right, that is they could have come loose. What you can try is to carefully remove the CPU (make sure you know how, and how to replace it) examine it on top and underneath. If the CPU had thermal compound on the surface, you may have to clean it and then replace new compound. You can carefully clean the top and the fan heat sink with rubbing alcohol, then dry it, and place new compound on it before putting back.
If so far nothing still is working, then you need to see if the CPU is good. Have a friend or use another computer to test it. If the CPU is good, continue.
If you are still having problems, the mother board may have a problem, such as a burnt out chip or other component.
These test options should get you to find the problems.
Posted on Oct 03, 2008
First to eliminate corrupt CMOS or Bios, remove the Bios battery (turn off psu, unplug power, keep one hand on case at all times, give 10sec. or more to discharge static before you touch anything, do not use metal screwdriver or anything metal). Turn on system, if it comes on it should run as default safe, shutdown before booting OS, Reinstall Battery (as above), reset Optimizations in Bios. If getting blue screens or memory errors you might want to upgrade Bios first. Then if you still get memory errors (boot with memtest86+, 2-3 passes are sufficient unless doing a stress test), replace memory.
If it's not either of those two No Display and no Beep means one of three things, PSU is dead, CPU is dead or MB is dead. Cheapest way to check PSU is have a Working psu connected to power and connect only the motherboard plug. If Bios comes on, you found the problem, if still not working remove CPU, if you get beeps, it's a dead CPU, if not dead MB. RIP :d
Posted on Oct 29, 2008
    Problem Solver:
Please translate this information. I'm brazilian.
Primeiro reset o CMOS.
Depois teste com outra fonte de alimentação.
Depois verifique se o cooler não travou e queimou o processador.
Boa sorte.
ramnses@itelefonica.com.br
Posted on Sep 01, 2008
No beep, No display, Shuts off after ten seconds.
i suggest you take it to a computer specialist
Dec 28, 2013 | Dell OptiPlex GX150 PC Desktop
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Hello, I have hp dv711 desktop with 3.0 G Hz. The problem with my system is, firstly when i boot it was showing green LED power nothing more then, nod display no hp bios page showing there. After 1 hour i...
make sure there is no disks in any drives then test your PSU and all leads that attach to your hard drive from electrical to IDE,SATA from your motherboard aswell then check all leads that attach to cd,dvd,3.1/2 floppy drives are secure and not faulty
hope this helps
Aug 12, 2010 | HP P4, 2.8GHz (305051001) Processor...
Won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
Oct 29, 2009 | HP RT935UAABA - HP Compaq dc7800...
PC can't boot LEDs are all Amber colour and flashing.
the memory sticks are not connected properly as you are getting the beeps out of the computer when turning on...
if in case the memory cards are connected properly the system should not beep while turning it on so please try to reconnect the memory cards properly & see if you are getting the prompt"the amount of system memory has changed" coming up in that case the system is working fine.
May 07, 2009 | Dell Dimension 3000 PC - P4 2.8GHz/256MB...
Computer will not boot or respond
Beeping upon startup is generally a problem with memory ..
Mar 13, 2009 | HP Compaq dx2000 PC Desktop
Troubleshooting
are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
Dec 06, 2007 | Compaq Presario SR1000T (568657) PC...
EliteGroup PT800CE-A Motherboard Logo
150 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
