Question about Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 User Key
I have a Ricoh Aficio 1045 I bought from an auction, and when I turn it on it asks me for a user key. I have no idea what the previous owner's user key was. Any way to bypass or set the unit to factory default settings? Thanks
  • mikemagee Sep 01, 2008
    I found online how to enter service mode, I cleared the memory, and everything is fine now.
  • Anonymous Mar 25, 2014
    I SET UP THE PRINTER BUT I STILL HAVE A RED LIGHT ON THE SCANNER
  • Ricoh Master
  • 2,794 Answers
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Posted on Sep 01, 2008
I bought this gestetner 3227 copier at a auction but it has user codes on it and I don't know how to get past them to use my copier, can you help?
Yes, you can delete the User codes.
But first see if you also have administrator code. You have to know that first and then you have clearance to change the User codes.
All these instructions are in the user manual. You can download for free on the website of RICOH. The equivalent of your machine is AFICIO 220.
Jan 28, 2011 | Gestetner Office Equipment & Supplies
My ricoh 2015 ask user code. I would like to know if there is any user code whitch can match with
You can see the existing user codes in this machine please fallow the procedure:
press usertoos/Counter button - then go to system settings and press ok button - go to key operator tools and press ok button - go to address book managment and press ok button - it will ask you the one search number give 001 and press ok button - it willask you name or displayes existing name simply press ok button - it will display an other window their you con find the user code option please press the user code button you con see the existing user code the exit and use that code to use the machine.
Other wise if you want to remove the user code option go to usertools/counter and go to systems settings and go to key operator tools and go to user code managment and sellect OFF by using up/down arro key and press ok button and exit switch OFF/ON machine directly come to copy mode- thanks
Dec 15, 2010 | Ricoh Aficio 2015 Copier
I have a ricoh 1045 , and I can not read the display looking down, but I can see everything in an angle. Can you help?
See the display panel contrast button position(in the left side to user tools button.).If not work perform the touch screen adjustment:Press the total stop key(yellow)-1-9-9-3-clear/stop key(red button) x5 timeand press enter key(double croice).The graphic sensing adjustment screen will appear.Touch the upper left corner then the lower right corner of the panel using a pointed tool.Touch a few spots on the LCD and confirm that the marker appear on the screen at exacrly the same location as the pointed tip.Touch enter on the screen adjustment.Turn off the machine and back on to store the settings.
Sep 26, 2009 | Ricoh Aficio 1035 Copier
How can I add or delete users for scanning? (Ricoh Aficio MP 5500)
Programming is under:
"User tools"
"System settings"
"Key operator"
"program/ change/ delete user codes" (or similar)
*please rate solution
Apr 14, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Chang the key
login as an admin without password and then you'll be able to change it.
Nov 24, 2008 | Ricoh Aficio 1035 Copier
How do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
Ricoh fax/copy machine
Instructions for 1013F are as follows:
above the blue numeric keys 2/3 there is a button with a small box with 123 in it this takes you in and brings you out of the USER TOOLS MENU.
Press user tool button once...user menu on display
use right arrow key...press3x..Fax Feature..press ok
right arrow2x..ok
again right arrow2x.ok....DATE/TIME on disply .ok
change then ok it once done exit by the 1st button you started with...USER TOOL BUTTON. all the best....
Mar 28, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1035 Copier Logo
388 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
